Moondrop
Moondrop Dark Saber In-Ear Headphones
Wearing style
Driver type
Balanced Armature, Dynamic
Introducing the Moondrop Dark Saber Hybrid Reference IEM, a class apart in the realm of in-ear monitors. Designed for the discerning audiophile, it strikes a harmonious balance between avant-garde technology, opulent aesthetics, and unmatched craftsmanship. Representing the zenith of audio perfection, the Dark Saber’s unique configuration and premium materials position it as a trailblazer in the audio market.
A Masterpiece of Craftsmanship
Drawing inspiration from the luxurious world of sports watches, the Dark Saber exudes opulence and precision. The faceplates, constructed from multi-layered high-strength carbon fiber, are not just robust but also aesthetically unparalleled. With each faceplate boasting a unique texture, every Dark Saber unit transforms into a distinctive piece of art, making it more than just an auditory device—it's a statement.
Unparalleled Sound Drivers
At the heart of the Dark Saber's breathtaking sonic performance lies its intricate driver configuration. With 2 dynamic drivers and 8 balanced armatures per side, it promises an all-encompassing audio spectrum. Whether you crave deep, thumping bass or crystal-clear treble, the drivers work in harmony to bring forth an audio experience where every nuance is captured and relayed with precision.
Redefining Bass Dynamics
For those with a penchant for deep and punchy bass, the Dark Saber’s Horizontally Opposed Double Dynamic Driver Module is set to be a game-changer. Comprising two 10mm dynamic drivers engineered using state-of-the-art 3D-printed components, it delivers bass that is not only rich and profound but also devoid of any distortions. It's an experience that transports listeners straight to the heart of live concerts.
Harmonious Sonic Equilibrium
A true musical masterpiece is one where every frequency is in harmony with the others. The Dark Saber achieves this auditory utopia via its full-frequency phase alignment. This meticulous arrangement guarantees a sound profile characterized by authentic timbre, exceptional clarity, and an expansive soundstage that encapsulates listeners, making them feel a part of the music rather than mere spectators.
Adaptable Connectivity Options
To cater to the diverse preferences of audiophiles, the Dark Saber comes equipped with a 0.78mm 2-pin interchangeable design. Whether you wish to pair it wirelessly with the MOONDROP LittleWhite Bluetooth Neckband cable or seek a wired connection with the FreeDSP complex function decoding cable, the Dark Saber is ready to accommodate. Experience true flexibility as the Dark Saber flawlessly adapts to your unique listening style.
| Technical Details | |
| Impedance | 22Ω±15% (@1kHz) |
| Sensitivity | 128dB/Vrms (@1kHz) |
| THD | THD@1kHz≤1% |
| Frequency Response Range | 7Hz-41kHz (IEC61094, Free Field) |
| Effective Frequency Range | 20-20kHz (IEC60318-4, 3dB) |
| Cable Jack | 0.78-2pin |
| Plug | 3.5mm Stereo Single Ended |
