1 of 4
Meze
Meze Rai Penta In-Ear Headphones
Regular price $1,099
Sale price $1,099 Regular price
Dynamic, Balanced Armature
Requires special order Special order items cannot be canceled, returned or refunded.
365-day returns
Meze
Meze Rai Penta Hybrid In-Ear Monitor Headphones
The Penta Hybrid technology delivers harmonized sound frequencies without the overlay of phase issues. For sound from the drivers to reach your eardrums it has to pass from through the housing / nozzle / eartip assembly. The seamless functioning of 5 drivers is enabled by the very specific and precise length of each sound tube which basically determines the air volume in front of each driver in particular. Meze's design eliminates imperfections that you can find in regular plastic Tube and Dampener systems, which are commonly used in multi-driver assembly.
Anatomical Fit
Ergonomics at its best. Pure comfort. Feeling of airiness and seamless fit. The comfier the IEM, the better the listening experience, this is a fact. Serious audiophiles will spend hours on end engaged in their music. RAI In-Ear Monitors are designed to deliver comfort and prolonged listening sessions allowing for a truly immersive experience for you and your music. Attention to details to an extreme: round, soft edges designed to embrace the natural curves from one’s ear and to fit perfectly.
Pressure Equalization System (PES)
Airflow control helps regulate internal chamber pressure trough Meze's finely tuned PES design in front and behind the driver assembly.
Full Metal CNC Sculpted Chassis
Meze Rai Penta In-Ear Monitor Headphones
The high precision CNC aluminum chassis, skillfully milled from solid aluminum, creates the perfect space for the sound to be precisely channeled to your inner ear directly and without distortion.
Super High-Resolution Sound Compatible
The Rai Penta work effortlessly with any device due to its low impedance and high sensitivity but to truly enjoy the potential of its painstakingly tuned driver array, we recommend a high-resolution source. The response is super high resolution and is above any certificate or standard. A balanced sound signature with impeccable micro-detailing provides unrivaled realism all across the wide frequency range, from 4Hz to 45 kHz.
Top Quality Cable to Bring Out the Best
Highest purity Silver-plated Copper wires terminated in finely crafted metal plug shells ensure that cable assembly will stay strong and reliable for a long time. There are 4 wires. Each wire consists of 20 litz strands. MMCX plugs are top quality and plug termination is rhodium plated for best connectivity and durability.
Tech Specs
  • Driver: Penta-Hybrid Driver
    • (4 x Customized Balanced Armature and 1 x Dynamic Driver working harmoniously together)
  • Frequency Range: 4Hz – 45kHz
  • Impedance: 20Ω
  • Sensitivity: 110dB SPL/1mW Sensitivity
  • Max Input Power: 30mW
  • Distortion: <1%
  • Stock cables: MMCX connector ending in 3.5mm, Rhodium plated
  • Warranty period: 2 years
What's In The Box?
Meze Rai Penta In The Box
  • Meze Rai Penta Hybrid In-Ear Monitor Headphones
  • MMCX braided cables made of silver plated copper custom wires ending in high quality 3.5mm
  • Hard Case: protective EVA case with Meze Audio metal logo
  • 4 pairs of soft silicone eartips XS, S, M, L
  • 1 double flanged eartips
  • 2 deep insertion double flanged eartips
  • 1 pair of comply foam eartips
  • 3.5mm to 6.3mm adapter
  • Airplane 2 pin adapter
  • Cleaning tool
