Matrix Audio
Matrix Audio Element X2 Music Streamer - Clearance
Regular price $1,899.99
Sale price $1,899.99 Regular price $4,399.00
1 of 7
Matrix Audio
Clearance
Premium Music Streaming Redefined
Experience music streaming at its absolute best with the Matrix Audio Element X2 Music Streamer. This flagship device offers a sophisticated blend of advanced technology and sleek aesthetics, designed to enhance your audio setup dramatically. With support for multiple input formats, including Toslink, USB, X-SPDIF, DSD, and Spotify Connect, the Element X2 is the definitive hub for audiophile-level streaming.
Exceptional Audio Fidelity with Dual ESS DAC Chips
The Element X2 harnesses the power of dual ESS flagship DAC chips, delivering extraordinary sonic precision and clarity. Whether you're listening to high-resolution PCM files up to 32-bit/768kHz, DSD512, or MQA streams, this streamer ensures your audio remains pure, detailed, and lifelike. Thanks to Matrix Audio’s meticulous engineering, every note is reproduced with accuracy and nuance.
Intuitive Touchscreen and Enhanced Interface
Navigate your music collection effortlessly with the Element X2’s vibrant, 3.46-inch full-color LCD touchscreen. Displaying comprehensive track, artist, and album information, the interface allows intuitive navigation through your favorite streaming platforms, local libraries, and settings. Touch-sensitive keys integrated into the sleek glass panel further enhance ease of use, creating a streamlined interaction experience.
Versatile Connectivity and Analog Flexibility
Bridging traditional and digital audio systems, the Element X2 offers extensive connectivity options. In addition to a range of digital inputs, it includes analog input ports compatible with turntables and CD players, allowing seamless integration of your analog gear. With configurable input gain levels, it effortlessly adapts to diverse audio devices, ensuring compatibility with your entire audio ecosystem.
High-Performance Balanced Amplification
Matrix Audio incorporates a fully-balanced headphone amplifier into the Element X2, utilizing eight independent amplification units. This sophisticated design significantly boosts drive current and output power, minimizing distortion and noise while enhancing audio dynamics. Whether pairing with high-impedance headphones or sensitive IEMs, the Element X2 provides robust and precise amplification tailored for superior listening experiences.
Advanced Clocking and Isolation Technology
The Element X2 utilizes the ultra-low phase noise Crystek CCHD-950 femtosecond clock, ensuring incredibly precise timing and jitter-free audio playback. Its isolated circuit design, employing independent power supplies for digital and analog sections, effectively eliminates electrical interference. This careful engineering results in pristine sound quality, revealing the finest musical details without background noise.
Seamless Control via MA Remote App
Manage your music effortlessly with the MA Remote App, available for both iOS and Android. The app centralizes control of local libraries, online streaming platforms such as TIDAL and Qobuz, internet radio stations, and device settings. Additionally, the intuitive app interface facilitates firmware updates and advanced configuration, placing complete control of your Element X2 at your fingertips.
Integrated HDMI ARC for Enhanced Multimedia
Enhance your multimedia setup with the Element X2’s HDMI ARC capability. Easily connect your TV or projector to route high-quality digital audio directly into your audio system. Supporting HDMI CEC, the Element X2 integrates seamlessly into your entertainment environment, delivering improved audio quality for all your visual content.
What's In the Box?
  • Element X2 Music Streamer
  • RM4 Remote Control
  • Power Cable
  • Quick Start Guide
  • Warranty Card
Feature Details
Hardware Platform CPU: NXP i.MX 6Quad 4x Cortex-A9 @1.2 GHz
D/A Chip ES9038PRO
Clock Source Crystek CCHD-950
Digital Input - Coaxial & Optical PCM 16-24Bit / 44.1kHz - 192kHz, DSD 2.8MHz (DoP)
Digital Input - IIS LVDS PCM 16-32Bit / 44.1kHz - 768kHz, DSD 2.8MHz - 22.4MHz (Native)
Digital Input - USB Audio PCM 16-24Bit / 44.1kHz - 768kHz, MQA, DSD 2.8MHz - 22.4MHz (Native)
Digital Input - HDMI ARC PCM 16-24Bit / 44.1kHz - 192kHz
AUX Input - RCA SNR: >-106dB, THD+N: <0.0025%, Frequency Response: 20Hz-20kHz ±0.07dB
Line Output - XLR SNR: >-131dB, THD+N: <0.00012%, Output Level: 4.5VRMS@0dB
Line Output - RCA SNR: >-125dB, THD+N: <0.00012%, Output Level: 2.2VRMS@0dB
Headphone Output - 4.4 mm Balanced SNR: >-119dB, THD+N: <0.00055%, Output Power: 2600mW@33Ω
Headphone Output - 6.35 mm Unbalanced SNR: >-116dB, THD+N: <0.00055%, Output Power: 1600mW@33Ω
Network - LAN 10/100/1000 Mbps
Network - WLAN 2.4 GHz / 5 GHz
USB Port 5V/1A power, supports FAT, FAT32, exFAT, NTFS
Trigger - In DC 6-12V<10mA
Trigger - Out DC 12V/50mA MAX
MA Player - Controller App MA Remote App
Local Playback Formats MP3, WMA, WAV, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSF, DFF, CUE
PCM Sampling Rate PCM 16-24Bit / 44.1kHz - 768kHz, MQA
DSD Sampling Rate DSD 2.8MHz - 22.4MHz
Streaming Services AirPlay 2, DLNA/UPnP, TIDAL Connect, Spotify Connect, vTuner
Power Voltage AC 100V-120V 50/60Hz / AC 220V-240V 50/60Hz
Standby Power Consumption < 5W
Maximum Power Consumption < 50W
Weight 4 kg (8.82 pounds)
Dimensions (W x D x H) 340 mm x 259 mm x 58 mm (13.39” x 10.20” x 2.28”)
Accessories RM4 remote control, Power cable, Quick start guide, Warranty card
