Mark Levinson
Mark Levinson № 5909 Active Noise Cancellation Headphones
Regular price $999
Sale price $999 Regular price $999.00
1 of 10
Mark Levinson
Regular price $999
Wireless
Highlights
  • Hi-Res Audio certified:
    • LDAC audio codec
    • Digital circuitry compatible with 24-bit/96kHz processing
    • Acoustic response up to 40kHz
  • Expertly tuned 40 mm Beryllium coated drivers acoustically optimized to the HARMAN Curve
  • Bluetooth 5.1 with LDAC, AAC and aptX™ Adaptive technologies
  • Adaptive Active Noise Cancellation (ANC) with three modes
  • Ambient Aware mode for situational awareness while on the go
  • Four-microphone voice array with Smart Wind Adaption
  • Available colors include Pearl Black, Ice Pewter, Radiant Red
Lose yourself in your music with the first-ever headphones from Mark Levinson, a pioneer in high-fidelity audio for the past 50 years. Reference-quality sound meets luxurious comfort in a lightweight and durable set of headphones featuring Adaptive Active Noise Cancellation (ANC) that’s perfect for travel. Reveal the hidden details in your music – at home, on the go, or anywhere you find a moment to listen.
Impeccable Performance
Experience incredible audio performance from these high-resolution wireless headphones, and discover all the nuances and subtleties in your favorite music. Featuring adaptive ANC to reduce background noise, the Mark Levinson № 5909 delivers reference-quality sound via 40 mm beryllium-coated drivers and high-resolution Bluetooth 5.1 connectivity.
Designer Sound
The № 5909 has been engineered to provide you with optimal sound for an over-ear headphone. Its sound profile has been expertly tuned to an acoustic response curve that achieved the highest subjective scoring across listening tests. Experience reference-quality sound, the culmination of decades of research into listening preferences and the science of acoustics.
Crystal Clear Calls
Hold conversations comfortably, in nearly any environment. Four beam-steering microphones with Smart Wind Adaption prevent your voice from being muddled by outside noise. At the same time, ANC blocks ambient sounds so you can focus on what’s being said. Connect with family, chat with friends, and hold business calls – all in near-perfect clarity.
Designed For Travel
Dive deep into your music and block out background noise as you travel. Three modes of Adaptive Active Noise Cancellation allow you to enjoy the subtle details in your music even amid noisy environments, such as during air travel. For added convenience, an Ambient Aware mode lets you talk to those around you without removing your headphones.
Materials
  • Premium leather headband and replaceable leather ear cushions
  • Anodized aluminum frame
  • Automotive-grade metallic painted ear cups
Battery
  • Up to 34 hours battery life; 30 hours playtime with ANC enabled
  • Up to 6 hours playtime with 15-minute quick charge
What’s Included
  • Hard shell carrying case
  • Cables (audio):
    • 4 m USB-C to 3.5 mm audio cable
    • 1.25 m USB-C to 3.5 mm audio cable
  • Cables (power):
    • 1.25 m USB-C charging cable
  • Adapters:
    • USB-C to USB-A adaptor
    • 3.5 mm to 6.3 mm audio adaptor
    • Airplane audio adaptor
  • Microfiber polishing cloth
Control
  • iOS and Android app control
What's In The Box
  • 1x Mark Levinson №5909 Premium Wireless ANC Headphones
  • 1x Travel Storage Case
  • 1x 1.25m USB-C to USB-C Charging Cable
  • 1x 1.25m USB-C to 3.5mm Proprietary Audio Cable
  • 1x 4m USB-C to 3.5mm Proprietary Audio Cable
  • 1x 3.5mm to 6.3mm Adaptor
  • 1x USB-C to USB-A Adaptor
  • 1x Airplane Adaptor
  • 1x Microfiber Polishing Cloth
  • 1x Quick Start Guide
Specifications
Download Specification Sheet
Download User Manual
Title Description
Type Premium High-Resolution Wireless Adaptive ANC Noise Cancelling Headphone
Driver Size 40mm
Driver Type Dynamic Beryllium Coated Driver
Frequency Response 10Hz – 40kHz (Passive)
20Hz – 20kHz (Active)
Sensitivity 97dB SPL @1kHz/1mW
Maximum SPL 98dB
Maximum input power (Passive) 100mW
Microphone Sensitivity -32dBV @ 1kHz/Pa
Impedance 32 ohm
Bluetooth transmitted power <8dbm
