Marantz
Marantz Model M1 Wireless Streaming Amplifier
Portability
Experience Audiophile-Quality Streaming with the Marantz Model M1
The Marantz Model M1 Wireless Streaming Amplifier combines powerful amplification and seamless wireless streaming in a sleek, compact form. Enjoy pristine audio quality up to 24-bit/192kHz resolution, enhanced by Marantz’s acclaimed engineering and proprietary Marantz Musical Digital Filtering (MMDF) technology, designed to deliver natural warmth, clarity, and engaging sound.
Powerful, High-Quality Amplification
Providing 100 watts of low-distortion amplification per channel, the Model M1 effortlessly drives your favorite speakers with rich, detailed audio. The built-in subwoofer output further enhances your listening experience, delivering deep, dynamic bass suitable for larger rooms or dedicated audio setups.
Versatile Wireless Streaming Capabilities
The Model M1 supports an extensive range of wireless streaming options, including HEOS Built-in, Apple AirPlay2, Bluetooth, and Spotify Connect. Whether you’re accessing your personal media library or streaming from your favorite music services, the M1 ensures exceptional audio quality and effortless connectivity.
Comprehensive Wired and TV Connectivity
In addition to wireless streaming, the M1 offers versatile wired connectivity options. Utilize digital TOSLINK and analog RCA inputs for traditional audio components. Enjoy superior TV audio with the convenient HDMI eARC connection, supporting Dolby Digital+ for an immersive home entertainment experience without needing a separate soundbar.
Multi-Room Audio Made Simple
Expand your listening experience throughout your home with HEOS Built-in. Connect the Model M1 to other compatible Marantz Hi-Fi or home theater systems to effortlessly create a multi-zone audio environment. Control your music seamlessly from room to room, bringing exceptional sound to every corner of your home.
Compact Design with Custom Installation Flexibility
The Model M1’s sleek, compact design makes it a perfect fit for modern living spaces, easily sitting within or atop AV furniture. Its innovative thermal management allows multiple units to be rack-mounted together without interference, perfect for custom installations. Additionally, a bottom-threaded mounting point provides flexible installation options.
Advanced Voice and Remote Control Integration
Conveniently control your Model M1 using voice commands with support for Amazon Alexa, Google Assistant, and Apple Siri. You can also integrate your existing TV remote for volume adjustments, enhancing ease-of-use. Capacitive touch controls and a dimmable LED front panel further refine your interaction with this advanced audio device.
Premium Craftsmanship from Shirakawa, Japan
Built with precision and care in Shirakawa, Japan, the Model M1 embodies decades of Marantz heritage and commitment to audio excellence. Its high-quality construction ensures durability and consistent performance, making it an exceptional addition to your home audio system.
| Amplifier | |
| Power Amplifier Rated Output & THD (8Ω) | 100 W + 100 W (8Ω, THD 0.05%) |
| Power Amplifier Rated Output & THD (4Ω) | 125 W + 125 W (4Ω, 1 kHz, THD 0.05%) |
| Frequency Response | 20 Hz to 20 kHz : ±1 dB |
| Connected Loudspeaker Impedance | 4 – 16 Ω |
| Audio Inputs / Outputs | |
| Loudspeaker Binding Posts | 4-way binding posts |
| Digital Inputs | HDMI (eARC), TOSLINK |
| Analog Inputs | RCA L/R |
| Subwoofer Out | RCA Mono |
| Inputs Audio Options | |
| Channel Assignments | Stereo (Default), Dual Mono |
| Volume Limit | 80-100% |
| Balance | -15dB to +15dB |
| Adjustable High Pass / Low Pass Filters | 40-250 Hz / 40-120 Hz |
| EQ | Bass, Treble -5dB to +5dB |
| Sound Modes | Stereo, Direct, Virtual, Dialog Enhancer, Night Mode |
| TV Sound Grouping | Yes |
| Audio Format Support | |
| Decoding | Dolby Digital +, Dolby Digital, LPCM, DSD |
| Stereo PCM / Multi-channel PCM | Yes / Yes |
| Stereo File Formats (HEOS or USB) | WMA: up to 192 kbps, AAC & MP3: up to 320 kbps, WAV, ALAC, FLAC: up to 24-bit/192kHz, DSD: 2.8 MHz, 5.6 MHz |
| Streaming Technologies | |
| Bluetooth Receive | BT 4.2.X |
| Bluetooth Transmit | No |
| AirPlay | AirPlay 2 |
| Spotify | Spotify Connect |
| Music Services and Sources | |
| Supported Music Services (HEOS) | Pandora, Spotify, TuneIn, SiriusXM, Amazon Music, Tidal, Tidal HiRes, iHeartRadio, Deezer, Deezer HiFi, Mood:Mix, Sony Hi-Res, AWA, QPlay, SoundCloud |
| Music Stored on Mobile Device | Yes (iOS, Android, Kindle Fire) |
| NAS | Network Share |
| USB Storage Device Playback | Yes (FAT32, NTFS formatted drives) |
| Networking & Control | |
| Wired Connectivity | Ethernet |
| Wireless Connectivity | Dual band, 802.11 a/b/g/n/ac |
| IR Input | 3.5mm |
| IR Learning | Yes |
| Control System Compatibility | Crestron, Control4, AMX |
| HEOS App | iOS, Android, Kindle Fire |
| General | |
| Product Color | Black |
| User Interface | Volume up/down, Play/Pause, Multi-colored LED, Connect button (rear), Bluetooth button (rear) |
| Dimensions (W x D x H) Inches | 9.41 x 3.31 x 8.54 |
| Dimensions (W x D x H) mm | 239 x 84 x 217 |
| Weight (lbs) | 4.84 |
| Weight (kg) | 2.2 |
What's In the Box
- Marantz Model M1 Wireless Streaming Amplifier
- Power cable
- HDMI cable
- Quick Start Guide
- Remote Control
- Batteries for remote control
- Warranty and safety documentation
