Klipsch
Klipsch Gig XXL Portable Party Speaker
Wireless
Portability
TAKE POWERFUL SOUND ANYWHERE
Introducing the Klipsch GIG XXL, a portable powerhouse that epitomizes Klipsch's 70 years of audio excellence. This wireless speaker packs a punch, delivering a sound that's not just big, but clear, detailed, and dynamic, easily outperforming its rivals. Wherever your journey takes you, Klipsch GIG XXL ensures the soundtrack is nothing short of spectacular.
CRISP HIGHS AND DEEP BASS
The GIG XXL boasts two 6.5” full-range drivers and a dedicated 2” tweeter, all finely tuned with advanced DSP equalization. This configuration allows for lifelike sound reproduction at any volume, ensuring that both the highs and lows of your music are delivered with exceptional clarity and depth.
MULTI-COLORED LIGHT SHOW
Elevate your party with the Klipsch GIG XXL's dynamic light show. Choose from a variety of modes to match your music's mood. The multi-colored light rings pulsate to the rhythm, while intense strobe effects add a thrilling visual dimension to your favorite tunes.
BLUETOOTH® WIRELESS TECHNOLOGY
Stream your music effortlessly with Bluetooth® wireless technology. Whether you're connecting a phone, music player, or computer, the Klipsch GIG XXL offers a seamless and reliable wireless connection, letting you enjoy your music without the hassle of wires.
8 HOUR RECHARGEABLE BATTERY
The Klipsch GIG XXL's rechargeable battery ensures your music keeps playing long into the night. With up to 8 hours of playback on a single charge, your party, gathering, or outdoor adventure will never be cut short due to a lack of power.
DURABLE BUILD QUALITY
Crafted to endure the rigors of the road, the Klipsch GIG XXL is as tough as it gets. Its sturdy construction can withstand the occasional knock, ensuring that your musical companion is ready for your rock 'n roll adventures.
AC POWER & CHARGING
Keep the GIG XXL energized with the included charging and power cable. Whether you're at home or on the move, recharging your speaker is convenient and hassle-free.
EASY TO CONTROL
The Klipsch GIG XXL is designed for ease of use. Control your music with simple, top-mounted controls or directly from your Bluetooth® enabled device, making it easy to adjust the volume, skip tracks, or pause your playlist.
BUILT FOR PARTY ENTHUSIASTS
The Klipsch GIG XXL isn't just about playing music; it's about being a centerpiece for your party. With an included microphone for karaoke and inputs for guitars, keyboards, or drum machines, it's the perfect party starter.
VERSATILE AUDIO SOURCES
With the Klipsch GIG XXL, you have multiple options for playing your favorite tunes. Stream wirelessly via Bluetooth, use the 3.5mm AUX port for wired devices, or plug in a USB flash drive for added flexibility.
EXPAND YOUR SOUND
For those big events, pair two Klipsch GIG XXL speakers via True Wireless for authentic stereo sound. Dual Bluetooth pairing allows you to connect multiple devices, ensuring a diverse and extensive music library at your fingertips.
The Klipsch GIG XXL is more than just a speaker; it's a statement in portable audio excellence, designed to bring high-quality sound and a fun atmosphere wherever you go.
