KEF
KEF Q1 Meta Bookshelf Speakers
Regular price $399.99
Sale price $399.99 Regular price $699.99
Save 43%
1 of 3
KEF
On sale
Save 43%
Passive Bookshelf Speakers - Pair
The KEF Q1 Meta Bookshelf Speakers bring KEF’s legendary audio innovation to a compact form factor. As part of the newly evolved Q Series, these two-way bass-reflex speakers combine the revolutionary Metamaterial Absorption Technology (MAT™) with KEF’s 12th-generation Uni-Q driver array, offering audiophiles unparalleled sound clarity, precision, and depth. Designed to blend seamlessly into any space, the Q1 Meta is perfect for music lovers seeking premium sound performance without compromise.
Revolutionary Metamaterial Absorption Technology (MAT™)
The Q1 Meta incorporates KEF’s groundbreaking Metamaterial Absorption Technology (MAT™), a game-changing advancement in audio engineering. MAT uses a highly intricate maze-like structure to absorb 99% of unwanted sound waves produced at the rear of the tweeter. This drastically reduces distortion and results in a clearer, more natural high-frequency response. Whether you’re listening to delicate acoustic passages or complex orchestral movements, MAT ensures that every note is delivered with precision and purity.
Uni-Q Driver Array for Exceptional Sound Dispersion
The Q1 Meta features KEF’s 12th-generation Uni-Q driver array, a hallmark of KEF’s innovation. This design positions the 25mm aluminum dome tweeter at the center of the 130mm midrange cone, allowing high and midrange frequencies to emanate from a single point source. This eliminates phase issues and expands the “sweet spot,” ensuring detailed and uniform sound throughout the room. The result is a listening experience that feels immersive, with balanced tones and stunning clarity regardless of your position.
Deep and Accurate Bass Response
Despite its compact size, the Q1 Meta delivers powerful and clean bass performance thanks to its optimized 5.25-inch hybrid aluminum low-frequency driver. Engineered for stiffness and low weight, the driver provides piston-like movement for fast, accurate bass response. The bass-reflex cabinet design incorporates a rear-firing flared port to minimize turbulence, delivering rich and articulate low-end frequencies. This makes the Q1 Meta ideal for both music and movies, adding depth to every track and scene.
Precision-Tuned Crossovers for Balanced Sound
To achieve seamless integration between its drivers, KEF has meticulously refined the crossover network of the Q1 Meta. Using over 1,000 specific measurements, KEF’s engineers optimized the signal path for pristine clarity and smooth transitions across frequencies. This attention to detail ensures that instruments and vocals are reproduced with natural timbre and lifelike accuracy. The result is a balanced sound signature that makes every genre of music sound spectacular.
Elegant Design and Versatile Placement Options
The KEF Q1 Meta features a contemporary, minimalist design with a choice of Satin Black, Satin White, or Walnut finishes, making it a stylish addition to any room. The compact bookshelf design allows placement on a tabletop, shelf, or dedicated speaker stand, and optional B2 Wall Brackets provide wall-mounting flexibility for smaller spaces. Each unit includes magnetic grilles for a clean aesthetic while protecting the drivers. Thoughtfully crafted, the Q1 Meta seamlessly blends performance and style.
Feature Details
Design Two-way bass reflex
Driver Array 12th Gen Uni-Q with MAT™
Tweeter 25mm (1 in.) vented aluminum dome with MAT
Midrange/Woofer 130mm (5.25 in.) aluminum cone
Frequency Range (-6dB) 47 Hz - 20 kHz
Typical In-Room Response 42 Hz
Frequency Response (±3dB) 51 Hz - 20 kHz
Crossover Frequency 2.1 kHz
Sensitivity 86 dB (2.83V/1m)
Amplifier Requirement 10 - 150 W
Harmonic Distortion <2% (140 Hz and above)
<1% (170 Hz - 20 kHz)
Maximum Output 108 dB
Impedance 4 Ω (min. 3.2 Ω)
Weight 6.1 kg (13.4 lbs.)
Dimensions (HxWxD) 11.9 x 7.1 x 10.9 in. (302 x 180 x 277 mm)
Finishes Satin Black, Satin White, Walnut
What’s In the Box
  • 2 KEF Q1 Meta Bookshelf Speakers
  • 2 Magnetic Grilles
  • 2 Foam Port Plugs
  • 8 Self-Adhesive Rubber Feet
  • Owner’s Manual
  • Warranty Information
  • Online Registration Card
  • Environmental Labeling of Packaging Sheet
Experience High-Fidelity Sound with KEF Q1 Meta
The KEF Q1 Meta Bookshelf Speakers combine cutting-edge technology and refined craftsmanship to deliver high-fidelity audio that exceeds expectations. Featuring MAT™, Uni-Q technology, and precision-tuned drivers, the Q1 Meta brings natural clarity, deep bass, and dynamic sound to your home audio system. With its sleek design and versatile placement options, it’s the perfect choice for audiophiles and music enthusiasts seeking premium performance in a compact, elegant form factor.
