KEF
KEF Kube 8 MIE Powered Subwoofer
Regular price $699.99
Sale price $699.99 Regular price $699.99
1 of 6
KEF
Pre-pay to reserve Shipping in March
Unleash the Power of Compact Bass with KEF Kube 8 MIE
The KEF Kube 8 MIE powered subwoofer is a testament to the fusion of compact design and powerful performance. Featuring an 8-inch front-firing active subwoofer, this remarkable piece of audio equipment is engineered to fill smaller rooms with deep, impactful bass. The integration of a 300 Watts Class D amplifier ensures unprecedented levels of control, allowing the Kube 8 MIE to deliver bass that is both dynamic and precise. This subwoofer is not just about powerful bass; it's about delivering an immersive audio experience that elevates your music, movies, and gaming to new heights.
Seamless Elegance Meets Advanced Technology
The KEF Kube 8 MIE is designed with a focus on both aesthetics and functionality. Its sealed cabinet design not only facilitates optimal placement but also ensures that it blends seamlessly with your room's decor. The subwoofer is equipped with KEF's proprietary Music Integrity Engine® (MIE), which uses advanced DSP algorithms to ensure perfect harmony between all components. This technology, including features like iBX Intelligent Bass Extension, allows for deeper and more precise bass at any listening level.
Feel the Force of Deep Bass
The Kube 8 MIE is all about delivering forceful bass that you can feel. The front-firing long-throw driver, with its large cone area and high excursion, ensures higher output at lower frequencies. The efficient and cool-running 300W Class D RMS amplifier further enhances the subwoofer's performance, making it an ideal choice for those seeking powerful bass in a compact form factor.
Versatile Immersion for Smaller Rooms
As the most compact model in the Kube range, the Kube 8 MIE is perfectly suited for smaller rooms. It is designed to elevate your movies, music, TV, and gaming experience, providing a level of immersion that is both versatile and impactful. Whether you're watching an action-packed film or listening to your favorite tracks, this subwoofer ensures that you're right in the middle of the action.
Effortless Wireless Integration
The Kube 8 MIE offers effortless wireless integration, thanks to the optional KW1 wireless subwoofer adapter kit. This allows for optimal placement without being limited by cables, ensuring that you can enjoy high-quality wireless transmission and the full nuance and impact of your favorite movies and music.
Well-Connected for Easy Integration
The Kube 8 MIE offers versatile connection options, including KEF SmartConnect and speaker-level inputs, making it easy to integrate into any system. Whether you're connecting it to your existing home theater setup or a new audio system, the Kube 8 MIE ensures a seamless and hassle-free integration.
Tailored Performance with Room Position EQ Options
The subwoofer features three room position EQ options, allowing for excellent performance no matter where it's placed in the room. These intuitive preset options ensure that you get the best possible sound from your Kube 8 MIE, regardless of its location.
Multiple Power Modes for Convenience
The Kube 8 MIE is equipped with multiple power modes for added convenience. The 'Auto wake-up' mode detects audio signals for instant readiness, the 'Always on' mode keeps it ready to play instantly, and the '12V trigger' provides automatic wake-up. These features ensure that your subwoofer is always ready to deliver powerful bass when you need it.
In the box, you'll find the Kube 8 MIE subwoofer, a power cord, a Euroblock speaker-level connector, and user manual and warranty information. Experience the immersive power of deep, detailed bass with the KEF Kube 8 MIE, a subwoofer that brings unrivaled acoustic accuracy to the heart of your audio setup.
KEF Kube 8 MIE Technical Specifications
Specification Detail
Design Powered Subwoofer (Sealed)
Drive units 1 x 200mm (8in.)
Frequency response 34Hz - 140Hz (-6dB)
Max output 105dB
Amplifier type Class-D
Amplifier power 300W RMS
Variable low pass filter 40Hz – 140Hz, LFE
Input RCA phono sockets, Speaker level inputs, Expansion port for KW1
Power requirements 100 - 240V, 50/60 Hz
Power consumption 300VA
Dimension (H x W x D) with rear panel and feet 293 x 293 x 310 mm (11.5 x 11.5 x 12.2 in)
Weight 9.4kg
