Kanto Living
Kanto S6 Desktop Speaker Stands
Regular price $59.99
Sale price $59.99 Regular price $59.99
1 of 13
Kanto Living
Improve your desktop listening experience with this pair of Kanto S6 Tilted Desktop Speaker Stands. Designed for 4 to 7" speakers, such as the Kanto Living YU6 and TUK, these stands tilt the front of your speakers upward by 16°. The angle of tilt is engineered to better deliver audio to your ears, allowing you to experience a fuller range of frequencies. Foam padding on the top and bottom of the stand work to reduce vibration as you turn up the volume. For compatible speakers, you can ensure that they stay in place on the stand with the included screws and integrated 1/4"-20 mounting holes.
Get the most out of your speakers
16 DEGREES OF TILT
Tilting your speakers upwards helps your ears capture a wider range of frequencies, improving the overall listening experience.
REDUCED VIBRATION
Foam padding on the top and bottom of each stand helps to isolate your speakers and reduce undesirable resonance.
Perfect companions
Pair your S6 stands with YU6 or TUK powered desktop speakers for a fully upgraded audio experience. Available in a variety of colors to compliment your setup.
