Kanto Living
Kanto S4 Desktop Speaker Stands
Regular price $29.99
Sale price $29.99 Regular price $39.99
Save 25%
1 of 11
Kanto Living
Save 25%
The Kanto Audio S4 desktop speaker stands are a pair of low-profile desktop speaker stands designed to securely hold a set of speakers for musicians, producers, and computer users in homes, editing suites, and personal offices. They feature solid metal construction for stability and strength, and foam isolation pads to minimize vibration and unwanted resonance.
Utilize the mounting holes and supplied 1/4"-20 screws to attach your YU4 speakers to the stands. With a weight capacity of eight pounds and a 5.5" wide by 7.9" deep surface, each stand is capable of supporting a variety of monitors. Once mounted, your speakers will be tilted 16° upward.
  • Low-profile design contributes to a sleek, clean appearance
  • Solid metal construction ensures stability and durability
  • Foam isolation pads on the top and bottom of each stand minimize vibration and unwanted resonance
  • 16° maximum tilt allows optimized placement and a customized sweet spot
  • Each stand supports up to eight pounds
  • Per-stand mounting hole and 1/4"-20 screw for secure attachment of your speakers
  • Raised rear tab prevents speakers from sliding back
  • Ideal for Kanto Living YU4 speakers or other monitors that fit on its 5.5" wide by 7.9" deep footprint
