Kanto Living
Kanto S2 Desktop Speaker Stands
Regular price $19.99
Sale price $19.99 Regular price $29.99
Save 33%
1 of 11
Kanto Living
Save 33%
Experience the full range of frequencies your speakers have to offer with the pair of S2 Desktop Speaker Stands from Kanto Audio. These sturdy, aluminum stands allow for 16° of vertical tilt and feature foam padding that provides grip and helps reduce vibration, so you can turn your speakers up loud without worrying about diminished sound quality.
16-Degree Vertical Tilt
Each S2 stand provides 16° of tilt to enhance your listening experience
Protective Foam Padding
S2 stands come with foam padding on the top and bottom to help grip your speakers securely, protect their finish, and absorb speaker vibration
Rear Support
The foam lined rear support keeps your desktop speakers secure and in place
Solid Aluminum Structure
Made from sturdy aluminum, S2 stands are built to securely hold small desktop speakers
Compatible with YU2
S2 stands were designed with YU2 in mind, allowing you to get the most out of your desktop speakers
