iFi Audio
iFi Audio iTraveller Carry Case - Clearance
Regular price $30.99
Sale price $30.99 Regular price $49.00
Save 37%
1 of 5
iFi Audio
On saleClearance
Save 37%
The iFi iTraveller is a multi-purpose travel case designed specifically for portable DACs and audio accessories. Compact, durable, and thoughtfully organized, it provides reliable protection for your gear while keeping everything accessible and neatly arranged when traveling.
With a padded interior, water-resistant materials, and flexible internal organization, the iTraveller is built for audiophiles who want to carry their portable audio setup safely without sacrificing convenience or style.
Key features
  • Designed specifically for portable DACs and audio accessories
  • Organized, tangle-free storage with removable and flexible compartments
  • Elastic belts and mesh pockets for adaptable organization
  • Dual cable ports allow connected devices to remain in use inside the case
  • Opens flat for easy access to all contents
  • Water-resistant nylon fabric with self-healing waterproof zipper
  • Outer storage pocket for quick access items
Use case and organization
The iTraveller is designed to keep your portable audio setup organized and protected on the go. It accommodates a portable DAC, IEMs, cables, adapters, a smartphone, and even a power bank, all within clearly separated compartments.
Soft, padded, removable partitions protect devices from scratches, while elasticated mesh pockets prevent cables and accessories from shifting during travel. Dual cable ports support connectors up to 6.3mm, allowing devices to remain connected while stored.
Technical specifications
Product type Portable audio travel case
Primary material Water-resistant nylon fabric
Closure Self-healing waterproof zipper
Internal layout Removable padded partitions, elastic belts, mesh pockets
Cable pass-through Dual ports suitable for connectors up to 6.3mm
Dimensions 135mm x 190mm x 50mm
What’s in the box
  • iFi iTraveller travel case
