iFi Audio
iFi Audio GO POD Ear Loop Optional Connectors - Clearance
Regular price $16.99
Sale price $16.99 Regular price $29.00
Save 41%
1 of 4
iFi Audio
On saleClearance
Save 41%
These iFi GO pod Ear Loop Connection Kits expand the compatibility of your existing iFi GO pod Bluetooth system, allowing you to pair the GO pod with a wider range of in-ear monitors. Designed as optional accessories, each kit includes a left and right ear loop and is available in multiple connector standards to match different IEM designs.
This product is an accessory only and does not include the iFi GO pod wearable DAC and amplifier.
Key features
  • Accessory ear loop kits for iFi GO pod Bluetooth system
  • Expands compatibility with multiple IEM connector standards
  • Includes two ear loops, one for each ear
  • Ideal as an additional set or replacement loops
Connection options and use case
These ear loop kits allow users to adapt the iFi GO pod to different in-ear monitors without replacing the core Bluetooth unit. This is especially useful for users with multiple IEMs that use different connector standards, or for replacing worn or damaged ear loops.
MMCX and 0.78mm 2-pin ear loops are included with the standard GO pod package but are also offered here separately for convenience.
Technical specifications
Product type Ear loop connection kit for iFi GO pod
Included quantity 2 ear loops (left and right)
Available connector types 0.78mm 2-pin, MMCX, Pentaconn Ear, Audio-Technica A2DC, Estron T2
Compatibility iFi GO pod Bluetooth wearable DAC and amplifier
What’s in the box
  • iFi GO pod ear loop connectors (1 left, 1 right)
