Great product and a great place to purchase from. Very good communication and they care about the business and customers. Thank you
Hifiman
Hifiman HE400se Entry-Level Headphones
Entry-level king of planar magnetic headphones
Cup style
Wearing style
Driver type
Amp required
HiFiMan HE400se: The Entriest Level Planar - Written review by FC Construct.
Headphones.com is happy to bring you the global version of the Hifiman HE400se Over-Ear Planar Magnetic Headphones which features Hifiman's unique stealth magnet design. The stealth magnet design is unique to the global version and is not including in the version available in China. The stealth magnet helps reduce wave diffraction turbulence and reduces distortion levels to barely audible levels.
Acoustically Invisible Stealth Magnet
Unlike the sound waves created by a conventional magnet, the special shape of Hifiman's stealth magnet enables sound waves to pass through the magnet without any interference.
Hifiman's advanced magnet design is acoustically transparent, reducing wave diffraction turbulence which would lead to a degradation of the sound waves. The reduced distortion yields pure sonic output that is accurate and full-range.
Maximum Comfort for Your Listening Pleasure
Thanks to the Hifiman HE400se's newly designed adjustable, lightweight headband, the HE400se remains cool and comfortable for hours, even in the most extreme heat.
The Hifiman HE400se planar magnetic headphones also come equipped with a newly designed driver casing for enhanced durability and protection from the elements.
Durable Connectors
The Hifiman HE400se ships with Hifiman's dual 3.5mm headphone side connectors and single-ended 3.5mm on the amp side with a 1/4" adapter. If there was any flaw with the HE400se, it would definitely be with the cable which we would recommend replacing when you have the chance. As the HE400se uses 3.5mm connectors, there are countless aftermarket cables that will do the job.
- Frequency Response: 20Hz - 20,000kHz
- Impedance: 32 Ohms
- Sensitivity: 91dB
- Weight: 385 grams
Specifications
| Title | Description |
Sensitivity
91dB |
Total Harmonic Distortion (THD)
Frequency Response
20Hz-20kHz |
| Driver Type | Planar Magnetic Driver |
| Driver Materials & Size | 100mm |
| Headphone Weight | 390 grams |
Warranty
1 year manufacturer's warranty |
