Hifiman
Hifiman HE1000 V4 Headphones Stealth Magnets - Open Box
Regular price $849
Sale price $849 Regular price $2,999.00
1 of 6
Hifiman
Regular price $849
The HE1000 V4 Planar Magnetic Open-Back Headphones from Hifiman have been updated from their previous model HE1000 headphones and offer redesigned earpads that are thick with an asymmetrical shape, a stronger cable, and polyester earpad surfaces instead of velour material to increase sound transparency for use in the home, studio, with portable devices, and more.
Featuring diaphragms so thin they are measured in nanometer thickness, the result is a pair of headphones that have a frequency response of 8 Hz to 65 kHz and an impedance of 32 Ohms. Their updated headband design will accommodate a wider range of head sizes. Their planar driver is the cornerstone of their remarkable sound.
The headphones have an updated earcup design that is trimmed down in size for a slimmer, sleeker look; they are now 11mm in thickness, a significant reduction in size from the original model's 14mm measurement. The earpads have become thicker with an asymmetrical shape that follows the form of the earcups. They are supplied with a cable that is made stronger with the improved materials of crystalline copper and crystalline silver wire, and built with a wide frequency range, low signal loss, and enhanced emphasis on their low-end for quality audio reproduction. A 1/8" cable and a 4-pin XLR cable are also included.
Key Features
  • These headphones feature an ultra-thin diaphragm for lightning-fast response, uncanny detail, and ultra-low distortion
  • They have a window-shade grille design that greatly reduces sonic reflections for clearer sound
  • The headphones have a lightweight, ergonomic headband for a better fit, improved sound, and better comfort for longer-term listening. They have been designed to accommodate a wider range of head sizes
  • Their Asymmetrical earcups follow the natural shape of the human ear and have been updated from the original 14mm in thickness to 11mm in thickness
  • They have a user-replaceable connector-cable design that allows for easily switching to or from other cables
  • The supplied cables are made stronger by incorporating crystalline copper and crystalline silver wire. They are custom designed for wide frequency range, low signal loss, and enhanced emphasis on the low-end for quality audio reproduction
  • The earpad surface that makes contact with the head has been changed from velour to polyester to increase sound transparency
Specifications
Title Description
Sensitivity More information
90dB
8Hz-65KHz
Driver Type Planar Magnetic
Driver Materials & Size
Headphone Weight 420 grams
Warranty More information
1 year manufacturer's warranty
