Hifiman
Hifiman Ananda Planar Magnetic Headphones - Stealth Magnets
Regular price $249
Sale price $249 Regular price $359.00
Save 31%
1 of 3
Hifiman
Regular price $249
Save 31%
Hifiman Ananda Reference Planar Magnetic Headphones | Available on Headphones.com
"The HiFiMAN Ananda has one of the most ideal frequency response curves for a wide range of music, coupled with excellent detail retrieval, speed, and imaging. Bass extends all the way into the sub-bass without any drop-off. It's tight, well-controlled, and doesn't drown out any of the rest of the frequency response. Mids are present, but not elevated, providing exceptional detail retrieval. In particular, 3-5khz isn't as noticeably dipped as is common with many other headphones, and this means piano tones, acoustic guitars, and female vocals come through with a unique clarity that isn't overshadowed by other parts of the mix. Treble is also handled exceptionally well without any peaks causing problems throughout the consonant range around 8.5khz. While the frequency response elevates to be moderately counter-clockwise tilted, it's still focused and non-fatiguing."
-Resolve Reviews
Hifiman Ananda Written Review - Review by Chrono
HiFiMAN Ananda Review - Planar Magnetic Headphones Refined - Review by Resolve Reviews
HiFiMAN Ananda vs. Arya - Planar Headphone Review & Comparison - Comparison & Review by Resolve Reviews
Check out Resolve Reviews' comparison between the HiFiMAN Ananda and Arya:
The HiFiMAN Ananda is here! First announced at the Munich High-End show in May of 2018, the Ananda represents a shift for HifiMAN. The HiFiMAN Ananda Planar Magnetic Headphones have low distortion and high sensitivity making them so easy to drive that you could even drive them from your phone!
The lightweight planar drivers feature thin, responsive diaphragms that produce a wide frequency response of 8 Hz to 55 kHz. Asymmetrical earcups and a hybrid headband design ensure comfortable wearing and balanced weight distribution. The supplied 3.5mm headphone cable is detachable for safe storage and transport, and a 6.35mm cable is included to allow compatible connectivity with audio interfaces and high-end headphone amps.
Key Features
  • Low impedance and high sensitivity allow the Ananda to be a suitable companion for mobile devices
  • At between 1 to 2 microns thick, the NsD (NEO supernano diaphragm) is 80% thinner than previous designs resulting in a faster more detailed response without compromising musicality
  • Each earcup features thick padding, pleather covering, and a robust 3.5mm female connector
  • The detachable 4.9' cable utilizes gold-plated 3.5mm connectors for maximum conductivity
  • Asymmetrical earcups follow the natural shape of the human ear
  • The headband is constructed of metal to maintain durability and incorporates a weight-dispersing strap for long-lasting comfort
Our take on the Ananda is that it has fairly neutral frequency response that's ever so slightly counter-clockwise tilted (brighter). The Ananda emphasizes clarity and detail but never gets harsh or sibilant, and simultaneously has well-known planar bass extension with minimal distortion for lower frequencies. The Ananda has a mid-sized stage that's presented more in front of the listener than laterally to the sides, and image distinction and instrument separation are both superb.
From Hifiman
ANANDA is the culmination of years of development. Lightweight, ultra-fine planar drivers at their heart sing with unmatched agility and power sensitivity.
High Sensitivity
Allows use with virtually any smartphone or portable audio device. Low distortion and amazing sound quality.
NEO "supernano" Diaphragm (NsD)
The all new NsD is 80% thinner than previous designs resulting in a faster, more detailed response while retaining lush musicality never before thought possible. At between 1 to 2 microns thick, the NsD diaphragm sets all be standards.
HIFIMAN has advanced its manufacturing processes to create this all new planar driver at unheard of prices. With the ANANDA at $699 retail, HIFIMAN has again set an all new bar for performance-to-value ration that the rest of the industry will have a difficult time following.
Window Shade Grill Design
Greatly reduces sonic reflections for clearer sound.
Asymmetrical Ear Cups
Follows the natural shape of the human ear.
Hybrid Headband Design
ANANDA has a carefully designed weight dispersing strap allowing the headband to afford outstanding levels of long-term comfort. The sleek and sumptuous matte black finish is combined with metal construction for maximum durability.
Making Connections
ANANDA comes with HIFIMAN's updated 3.5mm headphone connectors. This offers users the most robust headphone connector they have ever used giving both maximum survivability and enhanced longevity.
  • Frequency Response: 8Hz - 55 kHz
  • Sensitivity: 93 db
  • Impedance: 16 ohms
  • Weight: 398 grams
Specifications
Title Description
Sensitivity More information
103 dB
8Hz - 55kHz
Driver Type Planar
Driver Materials & Size
Headphone Weight 399 grams
Warranty More information
1 year manufacturer's warranty
FAQs
What's In The Box?
  • HIFIMAN ANANDA Planar Magnetic Over-Ear Headphones
  • 1x Headphone cable (1.5 metres) (3.5mm Jack)
  • 1x Headphone cable (3 metres) (6.35mm Jack)
  • 1x Pair of earpads (mounted on headphone)
  • 1x Adapter (3.5mm to 6.35mm)
  • 1x Warranty Card
  • 1x Owner's Guide
What is the Hifiman Ananda warranty?
HIFIMAN warrants to the original purchaser that the product purchased will be free of defects related to manufacturing, parts, materials, and workmanship under normal and accepted use. Shipment of the defective item for repair under this warranty will be at the customer’s own risk and expense.
The Hifiman Ananda comes with 1-year limited warranty.
Does the Hifiman Ananda require a headphone amplifier?
No. Hifiman specifically made the Hifiman Ananda to be extremely easy to drive and you can run them straight from your computer or your phone. However, for the optimal listening experience, we do recommend an amplifier. Something as simple as the Topping L50 will work great.
