HiFi Rose
HiFi Rose RS250A Network Streamer
Regular price $2,695
Sale price $2,695 Regular price $2,695.00
1 of 4
HiFi Rose
The Ultimate Audio-Visual Experience
Wired, Wireless
Requires special order Special order items cannot be canceled, returned or refunded.
Discover the HiFi Rose RS250A Network Streamer, a state-of-the-art device that combines a streamer, DAC, and pre-amplifier, designed for the modern audiophile. This high-performance network audio and 4K video streamer is perfect for those who crave both high-quality sound and visual entertainment. With its advanced features and intuitive design, the RS250A offers an immersive experience for music and video enthusiasts alike.
Elevated Design for Enhanced Performance
The RS250A’s design prioritizes both aesthetics and functionality. Crafted with rigid aluminum panels, it not only presents a sleek and elegant appearance but also effectively isolates micro-vibrations and maximizes thermal efficiency. This thoughtful construction ensures that the audio performance remains pristine and uninterrupted.
Intuitive Control at Your Fingertips
Experience the ease of use with the RS250A's 8.8-inch touch screen display. Effortlessly navigate between audio and video content with simple swipes and taps. The screen beautifully displays album art, music videos at 60 fps, and custom VU meters, making it a joy to interact with your music collection.
Unlimited Streaming Possibilities
The RS250A streamer is a hub for all your favorite streaming services. With the Rose Connect app, access a wide array of platforms like Apple Music, TIDAL, Qobuz, Bugs, Rose Tube, and internet radio. It is Roon Ready and offers seamless connectivity options, including Spotify Connect, Airplay, Bluetooth A2DP, and DLNA support.
4K Ultra HD Video Streaming
Go beyond audio with the RS250A’s 4K HDMI output capability. Enjoy YouTube content optimized for music lovers through the custom RoseTube app, or dive into TIDAL's extensive library of music videos and exclusive content. The VIDEO app also allows you to access and play your locally stored media with ease.
Customizable Internal Storage
The RS250A gives you the freedom to add a 2.5-inch SSD hard drive for storing your local music collection. This feature enhances the device's functionality, allowing for caching of frequently played music on TIDAL and videos on RoseTube for uninterrupted playback, even in fluctuating internet conditions.
Pristine Power for Pure Sound
HiFi Rose has meticulously designed the RS250A with a full linear power supply, ensuring a clean and stable power source for its CPU and audio output circuits. This design effectively blocks noise that could affect the sensitive DAC, resulting in crystal-clear playback and an authentic listening experience.
Enhanced CD Playback and Ripping Capability
The RS250A goes a step further in music management by allowing CD playback and ripping when connected to the optional RSA-780 external CD drive via USB. Extract sound sources from CDs as WAV or FLAC files, and save them to SSD or USB for a versatile and comprehensive music collection.
Effortless Control with Rose Connect App and Remote
Manage and control your HiFi Rose device with ease using the Rose Connect remote control app, available on various platforms including iPhone, iPad, Android phones, and PC. For added convenience, the RS250A also comes with a Bluetooth remote control, offering simple and efficient device management.
The HiFi Rose RS250A Network Streamer stands out as an exceptional device for audiophiles and video enthusiasts, offering unparalleled audio and video quality, intuitive operation, and a sleek design, all in one cutting-edge package.
Operating System: Customized Android 7.1 based Rose OS Ver 1.22.4
Design
Dimensions: 10.9" H x 7.9" W x 3" D
Weight: 7lbs
Materials: Aluminum Top Plate With Plastic Sides
Display: 8.8" Wide Viewing Angle Multi-Touch Panel
CPU: Hexa Core CPU
Dual-core Cortex-A72 up to 1.8GHz
Quad-core Cortex-A53 up to 1.4GHz
GPU: Mali-T864 GPU, OpenGL ES 1.1/2.0/3.0/3.1, OenVG1.1, OpenCL, DX11
Memory: LPDDR3 4GByte
DAC Chip: ES9028 Pro
Output Level: Max 2.3Vrms  (Unbalanced)
THD: 0.0002% (1kHz 2.3Vrms Unbalanced output)
THD + N: 0.0003% (1kHz 2.3Vrms Unbalanced output)
IMD: -102dB (SMPTE 4:1, 60Hz:7KHz)
Signal to Noise Ratio: 116dB (A-wt)
Dynamic Range: Max 126 dB (CCITT filter)
Stereo Crosstalk: Better than -133dB, 20-20kHz
Output Frequency Response: 20Hz to 40,000 (+/-0.5dB)
Output Impedance: 100Ω
Network Connection
Network Support: Ethernet 10/100/1000 BASE-T
WiFi (802.11 b/g/n/a/ac) 2.4Ghz/5Ghz Dual Band
Bluetooth: Bluetooth supported (A2DP Sink, AVRCP v1.3)
Audio Services:
Streaming: Airplay / DLNA / Roon Ready / MQA Full Decoder
Music Service: TIDAL / Internet Radio / Podcast
Input/Output
Audio Input: Line Input x 1, Optical In x 1, COAX x 1, USB Audio In x1
Audio Output: PreAmp Out (Unbalanced RCA) x 1, Optical Out x 1, COAX x 1, USB Audio Out x1,
Headphone Out x1
Video Output: HDMI 2.0 x 1 ( up to 3840 x 2160 / 60Hz )
Media Connection: USB3.0 x 2 ( File System - NTFS/FAT32, Supported Capacity - Max. 10TB )
SATA3.0 SSD x 1 ( File System - NTFS, Supported Capacity - Max. 4TB )
Network Support Protocol - SMB/FTP/WebDav
Supported Codec
Audio: MQA, WAV, FLAC, AIFF, WMA, MP3, OGG, APE, DFF, DSF, AAC, CDA, AMR, APE, EC3, E-EC3, MID, MPL, MP2, MPC, MPGA, M4A
PCM: 8KHz~768KHz (8/16/24/32bit per Sample)
Native DSD: DSD64(2.8MHz)/DSD128(5.6MHz)/DSD256(11.2MHz)/DSD512(22.5792Mhz)
Video: ASF, AVI, MKV, MP4, WMV, MPEG-1, MPEG-2, MPEG-4 H.263, H.264, H.265, VC-1, VP9, ​​VP8, MVC
H.264/AVC, Base/ Main/High/High10 profile@level5.1 up to 4Kx2K@30fps H.265
/HEVC, Main/Main10 profile@ level 5.1 High-tier up to 4Kx2K@60fps
Voltage/Power: Input Voltage : AC100-120V,220-240V 50/60Hz
Input Power : 50W
Update: SW update via Internet, USB OTA, Rose Store
Remote Control
Remote Control: Bluetooth remote control
Remote App: ROSE Connect (Android, iOS) / Google PlayStore, App Store
Accessories: Power Cord x 1, Bluetooth Remote Controller x 1 (AAA Battery x 2),
Manual x 1, SSD Screw x 4
