HiFi Rose
HiFi Rose RS150B Reference HiFi Network Streamer
Amplifier type
Wired, Wireless
Portability
The HiFi Rose RS150B is High-Performance Network Streamer provides various multimedia services with high-quality sound and ultra-high-resolution video.
Create your own high-quality sound station with RS150B.
Pure Sound
State-of-the-art DAC Setting
The RS150B uses the ES9038PRO Sabre chip with proprietary processing that offers a low-noise, low-distortion, ultra-high-resolution sound with rich analog density. Sampling rates go up to PCM 32 bit/768 KHz and native DSD512 (22.5792 Mhz).
Analog Acoustic Sensitivities
Delivers the musical inspiration from high-quality sound by the tuning of Acoustic engineers with thirty years of experience. Clearly expresses the full range, from grand, and rich bass to delicate, and elegant highs.
Linear Power System and Ideal Circuit system
Linear power supply minimizes noise inflow significantly. Ideal circuit system eliminates electrical noise, and creates dramatically improved sound quality without distortion.
Highly Precise Femto Clock
The highly precise Femto clock delivers superb stereoscopic, and distortion-free sound with quiet and clear background imaging.
Case milled from Solid block of High Purity Aluminum
The high-purity aluminum integrated into one piece to maximize thermal efficiency. By minimizing parts in the assembly area, vibrations that can affect sound qualities are greatly reduced, creating a profound and ideal sense of space.
MQA Certified
Ultra HD 4K Video Support
Advanced Control
14.9-Inch-Wide Touch Screen
ROSE Connect Application
This intuitive and dedicated application allows users to play all music and videos from local and network sources.
Bluetooth Remote Controller
Innovative ROSE OS
Music & Video
Play music and video files on a local storage device (USB / MicroSD / SSD). Also, you can build your home network library with a NAS connection. It is possible to categorize your music in numerous ways.
TIDAL
Built-in Tidal App for high-performance streaming service. Easily integrate all existing features, such as sign-in, playlist, and playback.
Roon Ready
Roon is an incredibly rich and engaging way to browse and organize your music. It runs on most Mac, Windows, and Linux PCs, or on other products which include Roon Core. Being Roon Ready means that HiFi rose network players transparently discover and connect to Roon without any configuration, and bit-perfect audio is delivered from Roon to your network player. Together, Roon and HiFi rose deliver the power, flexibility, and performance of networked audio, with the easiest setup and highest reliability available. Learn more about Roon partner programs.
CD
By connecting an external CD-Rom Drive via USB, spontaneous CD playback is possible. You can extract music files stored on a CD and save them to SSD, USB, or MicroSD.
Radio & Rose Podcast
Listen to more than 990 Internet radio stations from around the world. Register and listen to your favorite channel. It also offers podcast channels, provided by iTunes.
Rose Store
You can simply update these applications to the latest version from the RoseStore App.
Spotify Connect
Spotify Connect allows you to play and wirelessly control Spotify music on your ROSE OS over a network. With the Spotify Connect function, you can enjoy a variety of music with hi-fi sound quality on your ROSE device.
Qobuz
Enjoy music streaming with Qobuz's various functions. Support for hi-res audio (24 bit/192 kHz) means you can enjoy high-resolution music.
Connect Anything
Wired/Wireless Connection
Seamless streaming over the network is possible. It supports Airplay and DLNA functions and can connected to smartphones, computers and tablet PCs via Wi-Fi / Giga Ethernet / Bluetooth communication.
Build a home media library
Designed to contain enough storage in consideration of listening to HiFi music sources, RS150 can recognize up to 4TB of SSD, 10TB of external HDD, and 400GB of MicroSD. Also, it supports connection with NAS. Experience high-quality music without worrying about drive capacity from now on.
High Performance Input / Output Terminal
Compatible with multiple devices via several kinds of terminals. Supporting a variety of input and output terminals, RS150 completes the ultimate connectivity.
