HEDD Audio HEDDPhone® Two - Open Box - Clearance
Audio evolution.
On back order
5-year warranty
HEDD offers a full factory warranty on all parts and labor
Exclusive retailer
We partnered with HEDD to give you the best HEDDPhone® Two buying experience.
Open-box C condition are open box items that are not in like-new condition. They may show signs of wear, have packaging that is imperfect and be missing accessories. Clearance items are sold as is without a warranty guarantee and no returns.
In a vibrant world of audiophile gear, the HEDD Audio HEDDphone Two stands as a testament to relentless innovation and technological mastery. The culmination of three dedicated years of rigorous R&D, the groundbreaking HEDDphone TWO promises an auditory experience that is unparalleled in depth, clarity, and fidelity. Crafted meticulously with an all-new mechanical design, it embodies a perfect marriage of compactness and enhanced durability. Whether you are in a high-stakes professional studio setup or a discerning everyday enthusiast craving for sublime audio experiences, the HEDDphone Two is structured to meet your demands with a finesse that is simply unmatched. When you own a HEDDphone Two, you are not just investing in a gadget, but a masterpiece carved out of years of dedicated craftsmanship and innovation.
Stepping into the next frontier of personal audio, the HEDDphone Two shows that HEDD Audio listened to your feedback on the original HEDDphone and brings to you an all-new dimension of comfort and customization with its revolutionary patent pending HEDDband system. This remarkable innovation empowers you to modify various aspects including height, width, curvature, and clamping pressure, thereby promising a tailor-made fit that embodies comfort even during extended listening sessions. The centerpiece of this auditory marvel is the Variable Velocity Transformation (VVT) technology that synergizes harmoniously with the AMT driver nestled inside the HEDDphone. This state-of-the-art technology guarantees an even frequency response traversing the entire audio spectrum, delivering an immersive sound experience that will captivate your senses in every note. Step into a new era of acoustic excellence with the HEDD Audio HEDDphone Two.
The first 150 preorders will receive a limited edition HEDDPhone Two artist print — exclusive to Headphones.com
Our HEDDPhone® TWO First Impressions
Check out reviews from The Audio Files and The HEADPHONE Show
Innovative new driver technologies open up a world of possibilities. And a world of challenges. But HEDD Audio made sure to listen to the feedback of the headphone community to bring us the HEDDPhone 2. They’ve cut down its weight by 25% of the original HEDDPhone and incorporated the most adjustable headband I’ve ever seen. The HEDDPhone 2 retains its predecessor’s treble brilliance and transient response to deliver a listening experience utterly unique to HEDD Audio’s Air Motion Transformer (AMT) drivers.
HEDDPhone® Two - Open Box - Clearance Features
Cup style
Wearing style
Driver type
Amp required
Cutting-edge engineering
HEDDphone TWO is the culimation of three years of relentless R&D. Every aspect as been refined for an unparalleled audio experience.
New HEDDband® – Designed for all day comfort
With a pending patent, this smart strap system enables you to personalize height, width, curvature, and clamping pressure, ensuring a tailor-made fit that’s comfortable for prolonged use.
Handmade in Berlin
HEDD crafts its flagship HEDDphone TWO headphones for audio professionals with a remarkable fusion of cutting-edge technology and meticulous craftsmanship. A result that also resonates with the discerning ears of audiophiles.
By reconstructing the driver from scratch and using lightweight materials like carbon fibre and magnesium, the HEDD R&D team was able to achieve a staggering 25% weight reduction. An all new mechanical design was developed in order to make the product more compact and durable.
AMT driver technology
With a folded Kapton diaphragm over three times larger than in traditional dynamic, planar, or electrostatic driver designs, the sound of HEDDphone TWO has reached new heights with regards to precisely tailoring subtle transients and creating a transparent, natural musicality.
HEDDPhone® Two - Open Box - Clearance Media Gallery
HEDDPhone® Two - Open Box - Clearance Specifications
Technical Specs
| Title | Description |
| Design | Open-back over ear headphone |
| Driver | AMT with full-range VVT® technology |
| Frequency Response | 10 Hz - 40 kHz |
| Efficiency | 89 dB SPL at 1mW |
| Impedance | 41 Ω flat |
| Power requirements | min. 200mW, recommended ≥ 1000 mW |
| Connection | symmetric 3.5mm |
| Cable | Kevlar-infused, graded. |
| Pads | Faux leather ear pads and heat cushion. |
| Weight | 550g |
Frequency Response Graph
Patent-Pending HEDDband Technlogy
Explanation Video
Innovation isn't easy and HEDD Audio's new patent-pending HEDDband system is no different! Luckily, we've got a handy video to help guide you through using HEDD's new HEDDband system to ensure that when your HEDDphone TWO arrives, you'll be set and ready to listen in no time.
“Sound is heard through space. I can feel the most private space between the headphones and our ears, a new way to carry around the mixing studio.”
What’s in the box
- Travel case to fit HEDDphone TWO
- A spare set of ear pads
- 2.2m headphone cable with 6.35mm termination
- 2.2m balanced cable with 4.4mm termination
- 3-pin audio adapter – 6.35mm to 3.5mm
- 4-pin audio adapter – balanced 4.4mm to XLR
The Brand
The impact of Heinz’s loudspeaker developments, particularly with his patented air motion transformer (AMT) driver, has left an indelible mark on the current generation of speaker manufacturers. His visionary designs have been directly applied to or strongly echoed in the works of renowned names ADAM Audio, Eve Audio, Unity Audio, Elac, Presonus, and ESI, among others. The current leaders of loudspeaker design have literally grown up around Heinz innovations.
The ethos of HEDD Audio remains to create the highest quality loudspeakers and headphones for professional and hi-fi applications. But our developments extend beyond the AMT driver and encompass groundbreaking advancements in port technology, the art of speaker linearization, and even further refinements of our own AMT driver, such as the Variable Velocity Transform (VVTTM) technique.
- Choosing a selection results in a full page refresh.
- Opens in a new window.
