Focal
Focal Clear Headphones - Open Box
Regular price $699
Sale price $699 Regular price $990.00
1 of 3
Focal
Regular price $699
The Focal Clear is a new over-ear open-back headphone from Focal made for audiophiles. The Clear bridges the gap perfectly between the Elear and the Utopia, finally giving you an option between their price points. The Clear has all the strengths of the Elear with none of its faults. Gone is the mid-range dip and uncomfortable pads. The Clear has excellent bass extension, clear, detailed mids and highs that truly stand out. The Clear also features perforated memory foam cushions and a lighter design meaning it can be used for extended listening periods with ease!
The Focal Clear features leather and perforated microfiber adjustable headband with ear cup rotation and a one size fits all Aluminum Yoke with 20mm memory foam ear cushions. The Clear from Focal has low impedence (55 Ohms) which means taking it on the go with a high-resolution digital audio player is easier than ever! The Clear also features 3.5mm locking jack sockets and comes with 3 cables (instead of just the one cable provided with the Elear and Utopia). Discover a listening experience similar to that provided by high-fidelity loudspeakers and excellent performance when connected to portable high-resolution audio players.
*Headphones.com is very pleased to announce that you have even more options to pay for your Focal Clear headphones! Now when you hit the Pay with Crypto button, you have the option to pay with cryptocurrencies like NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
Specifications
Title Description
Sensitivity More information
104dB SPL / 1mW @ 1kHz
0,25% @ 1kHz / 100dB SPL
5Hz - 28kHz
Driver Type Dynamic
Driver Materials & Size 1.6" (40mm) Aluminum/Magnesium 'M'-shape dome
Headphone Weight 450 grams
Warranty More information
3 years manufacturer's warranty
Written review
FAQs
What is included in the box?
  • Focal Clear Headphones
  • Hard Carrying Case
  • 3 cables (3.5mm, 6.35mm, XLR 4 pin connector)
Are these headphones open-back or closed-back?
Open-back
What devices are compatible with these headphones?
Focal Clear comes with 3 cables that is compatible with every type of electronic equipment (3.5mm mini jack, 6.35mm jack and XLR 4 pin connectors). Focal Clear headphones don't require a headphone amplifier/DAC but you will notice significant improvements in sound quality if you use one.
How do these headphones fit?
These headphones have perforated microfibre earpads and headband to provide cushioning, allowing for hours of listening without discomfort.
Is there a wireless option to connect via bluetooth?
These are wired-only headphones.
What does "open-box" mean?
An "open-box" product means it has been opened before. These are typically returned products or demo models. There are several possible reasons why an item is returned, and not because it has been damaged.
