Focal
Focal Chora 826 3-Way Floorstanding Speakers - Black - Each - Clearance
Regular price $599.99
Sale price $599.99 Regular price $1,199.00
Save 50%
1 of 3
Focal
On saleClearance
Save 50%
2 units available, sold as individual units
The Chora 826 is the flagship floorstanding loudspeaker in the Chora lineup, designed to deliver full-range performance with clarity, scale, and control. Built around Focal’s proprietary Slatefiber drivers and paired with an advanced aluminum magnesium tweeter, the 826 offers a powerful yet balanced presentation that works especially well in medium to large listening spaces.
With a front-ported bass reflex design, refined cabinet geometry, and a time-aligned tilted stand, the Chora 826 is engineered to produce a cohesive soundstage with impactful low end and articulate midrange detail.
Balanced, Full-Range Performance
The Chora 826 uses a three-way driver configuration to maintain clarity and separation across the entire frequency range. Dual 6.5 inch Slatefiber woofers provide controlled, dynamic bass with strong extension, while the dedicated midrange driver preserves vocal presence and tonal accuracy.
An aerodynamic front port reduces turbulence and distortion, allowing the low frequencies to remain clean and well-defined even at higher listening levels.
TNF Aluminum Magnesium Tweeter
High frequencies are handled by Focal’s TNF inverted dome tweeter, made from an aluminum magnesium alloy for speed and precision. The tweeter uses a Poron memory foam surround, derived from Focal’s Utopia designs, to reduce distortion in the critical 2 kHz to 3 kHz range where the human ear is most sensitive.
This design delivers smooth, detailed treble with wide dispersion, allowing consistent tonal balance throughout the listening room.
Slatefiber Cone Technology
Exclusive to Focal, Slatefiber cone technology uses recycled non-woven carbon fibers arranged in a uniform direction and sandwiched between thermoplastic polymer layers. This structure improves rigidity and damping while keeping the driver lightweight.
The result is a sound that is fast, controlled, and natural, with excellent transient response and tonal balance across bass and midrange frequencies.
Design and Finish
The Chora 826 features a clean, modern cabinet design mounted on a tilted base for improved time alignment and imaging. The visual contrast of the Slatefiber cones adds a distinctive yet understated aesthetic.
Available finishes include Black, Light Wood, and Dark Wood, making it easy to integrate the speakers into a wide range of living spaces.
Brand Focal
Model Chora 826
Speaker Type 3-way floorstanding loudspeaker
Enclosure Type Front-ported bass reflex
Tweeter 1 inch inverted aluminum magnesium dome
Midrange Driver 6.5 inch Slatefiber
Woofers Dual 6.5 inch Slatefiber
Frequency Response 48 Hz to 28 kHz
Sensitivity 91 dB
Nominal Impedance 8 ohms
Recommended Power 40 to 250 watts
Bi-Amp Terminals No
Cabinet Material MDF with vinyl wrap or wood veneer
Available Finishes Black, Light Wood, Dark Wood
Weight 46.6 lbs each
Dimensions (H x W x D) 40 7/8 x 12 x 15 7/8 inches
Warranty 5 years
Who the Chora 826 Is For
The Chora 826 is well suited for listeners who want a full-range floorstanding speaker with strong bass presence, wide soundstage, and refined detail without moving into ultra high-end pricing. It pairs well with a wide range of amplifiers and excels in larger rooms where scale and impact matter.
