Final Audio
Final Audio ZE8000 MK2 True Wireless In-Ear Headphones - Clearance
Regular price $179.99
Sale price $179.99 Regular price $399.00
Save 55%
1 of 4
Final Audio
On saleClearance
Save 55%
ZE8000 MK2 with enhanced audio quality, improved comfort and added features – experience the evolution of ‘8K Sound’. With the ZE8000 MK2, Final has made significant improvements for an all-new user experience. Including new ‘Shield Fin’ eartips for improved comfort and increased passive sound isolation, enhanced signal-to-noise ratio for greater detail retrieval and improved ‘8K Sound’, the ability to deactivate ANC and other noise control settings, and a maximum volume increase of 5dB.
Immersed like never before
Development of the ZE8000 MK2 has enabled the evolution of Final’s ‘8K Sound’ feature. Improving the signal-to-noise ratio through hardware and software interventions provides a clearer perception of ‘8K Sound’, extracting more detail and musical nuance from recordings.
“As a concise and concrete example to convey this evolution, we consider the ZE8000 MK2 as earphones that immerse you in the orchestra." – Final.
The ZE8000 MK2 hardware and software improvements have provided fertile ground for a more efficient integration of ‘8K Sound’, ensuring a more faithful reproduction of recorded instruments and their unique timbre. This ability to faithfully and vividly reproduce the balance of recorded instruments extends to all music genres, elevating the listening experience by significantly increasing the amount of information in the sound.
Compared to the initial model, the ZE8000 MK2 achieves a 32% improvement in sound isolation with ANC active. This is achieved by a combination of internal structure enhancements, newly designed 'Shield Fin' earpieces, and a refinement of the algorithm for active noise cancellation.
Utilising an FIR filter for frequency and time domain corrections, combined with a unique integration of multiple digital signal processing techniques enables the achievement of high-definition and distortion-free ‘8K Sound’ In the ZE8000 MK2. Compared to the initial model, the digital signal processing has been refined, allowing for a clearer perception of ‘8K Sound’ even in finer details.
Improved comfort and fit = improved sound quality
With the ZE8000 MK2, Final has included newly designed ‘shield fin’ eartips. These tips come in a wide range of sizes and offer an increase in passive isolation as well as a more comfortable and secure fit. This increase in isolation benefits the sound quality due to a reduction in ambient noise and improved seal provided by the ‘shield fin’ technology and silicone material used.
The eartips come in five different sizes (SS/S/M/L/LL) to ensure the optimal fit and comfortable listen for all ear shapes and sizes.
New features and updated ‘Final Connect’ app
After listening to feedback from the first release, Final has included the ability to deactivate ANC and all other noise control settings. This provides users with an unfiltered experience of the Final ZE8000 MK2 and ‘8K Sound’
The maximum volume has also been improved upon with a 5dB increase, as well as an overall redesign of Final’s ‘Volume Step Optimization’ feature within the ‘Final Connect’ app for finer volume adjustments.
Users can check the individual volume levels of their ZE8000 MK2 via the ‘Final Connect’ app as well as a number of other features and settings for an improved experience:
· Switch between the 4 modes of noise cancellation/ambient sound intake.
· Easily adjust sound quality like a professional engineer with the "Pro Equalizer" settings.
· Fine-tune volume adjustments to your optimal level with the "Volume Step Optimization" settings.
· Switch between voice guidance languages (Japanese/English).
· Toggle to "8K SOUND+ Mode."
· Switch to touch operation disabled mode.
· Configure/switch Multi-Point settings.
The ZE8000 MK2 supports Qualcomm's latest audio platform, Snapdragon Sound™. With aptX Adaptive (24bit/96kHz), users can enjoy high-resolution audio with high quality and low latency.
By strategically placing two high-performance microphones at a distance, the ZE8000 MK2 enables beamforming towards the mouth. This feature ensures clear voice transmission, eliminating ambient noise even during outdoor calls.
Product Specifications:
  • Communication Method: Bluetooth® 5.2
  • Supported Codecs: SBC, AAC, Qualcomm® aptX™, aptX™ Adaptive
  • Continuous Music Playback Time: Up to 5 hours / Including case: Up to 15 hours
  • Charging Time: Earphones: Approximately 1.5 hours / Charging case: Approximately 2 hours
  • Rapid Charging: 45 minutes of music playback with a 5-minute charge
  • Battery Capacity: Earphones: 54mAh / Charging case: 420mAh
  • Waterproof Rating: IPX4
Accessories
  • Charging case
  • ZE8000 MK2 exclusive ear tips (SS/S/M/L/LL sizes)
  • USB Type-C charging cable
  • acoustic fixture
  • dust filter
