Final Audio ZE3000 True Wireless Earbuds
Cup style
Wearing style
Driver type
Wireless
365-day returns
Final Audio
Final ZE3000
ZE3000 are true wireless earbuds from Final, focused on providing convenient HiFi sound anywhere you go.
While many true wireless earbuds on the market focus on features with audio as an afterthought, Final's engineering team in Japan has applied their knowledge accumulated in acoustic research and psychoacoustics to deliver exceptional sound quality for this price point.
The newly developed f-Core for Wireless driver unit delivers balanced audio and ultra-low distortion, resulting in a sound quality that is unmistakably different from conventional truly wireless earbuds. The goal: to convey the intentions of artists and creators by creating a clear and natural sound.
Superb HiFi Sound Quality
Final's knowledge of acoustic engineering and psychoacoustics lead to the development of ZE3000. Rather than being designed to create impactful surprise on the first listen with exaggerated highs and lows that can quickly become fatiguing, these earbuds are meant for long-term music enjoyment and appreciation.
The principal challenge with truly wireless earbuds are that batteries, electronic circuit boards, and antennas need to occupy most of the space inside the housing. This means that there is less freedom to create a perfect acoustic chamber to achieve a high quality sound.
While most truly wireless earbuds rely heavily on software equalization to address this issue, the ZE3000's development process focused on improving the fundamental performance of the driver units; the new 6mm f-Core for Wireless dynamic driver has been manufactured from scratch to achieve ultra-low distortion. Optimizing the acoustic space inside the earbuds was key to achieving satisfying audio performance — only then is minimal software equalization used to make precise pinpoint effective adjustments in narrow bands.
IPX4 Water Resistance
The ZE3000 is designed to be water-resistant to the IPX4 standard, able to withstand sweat during sports and everyday rain.
However, this water resistance requires the earbud housing to be completely sealed without a vent to regulate the air pressure inside the acoustic chamber, resulting in low-frequency sounds becoming overwhelming and causing overall clarity to degrade. Most manufacturers opt to increase the high frequencies in order to balance the overall sound presentation, but the audio becomes overemphasized on both low and high frequencies, resulting a less natural and more fatiguing sound.
Final designed a new f-LINK Damping System for ZE3000 to address this issue. It optimizes the pressure in the acoustic space within the earbuds to create great sound without the need for external vents. This makes it possible to properly control the low frequencies that are often problematic in truly wireless earbuds — combined with the ultra-low distortion of the driver unit, Final has achieved a fine and detailed expression of the bass range.
High Quality Codec Support
ZE3000 is easy to pair with a wide range of iPhone, Android, PC, and Mac devices.
In addition to the widely-used SBC and AAC codecs, it also supports the high-quality Qualcomm aptX and aptX Adaptive codecs for 48kHz/24bit wireless transmission where available.
Up to 35 Hours of Music Playback
Shibo is an old Japanese word meaning a wrinkle on the surface of paper or leather. This inspired the soft-textured coating of the ZE3000 earbuds and case, a beautiful surface that is superb at resisting dirt and fingerprints while sporting a subtle yet premium textured look.
Award-Winning Eartips
Convenient Touch Control
By simply opening the lid of the charging case, the ZE3000 will enter its pairing mode ready for its first pairing. After the pairing is completed, every time when the case opened, the connection will automatically be established with the previously paired device.
Single Ear Mode
- ZE3000 Earbuds
- Charging Case
- TYPE E Truly Wireless Tips in 5 sizes
- USB Type C Charging Cable
