Final Audio
Final Audio D8000 Pro
Cup style
Wearing style
Driver type
Amp required
D8000 Pro Edition
Life style
2019, Japan
This is the same principle as earphones with sealed earpieces being able to reproduce bass frequncies despite their small size. By sealing the inner earpads, it is possible to produce bass tones across low frequency bands; these become the bass tones produced within a sealed space the same as earphones.
With D8000, the problem with the diaphragm coming into contact with magnets has been solved through AFDS (Air Film Damping System), and it has become possible to reduce the frequency of the bass tones that the driver unit can reproduce. Combined with breatheable earpads, bass tone reproduction with a volume and open sound only achievable with superior dynamic models is possible.
In reproducing subtle high frequencies, the lightweight nature of the diaphragm comes before anything else. Compared to other dynamic models with the same diameter, D8000's diaphragm is 1/3 lighter. A super thin aluminum coil has been etched on the extremely lightweight film diaphragm, and as such, the adhesive essential for use between the coil and the diaphragm of dynamic models - which has a very negative effect on sound quality - is not necessary. With the D8000 Pro Edition, problems originating from the adhesive have been fundamentally resolved, and the reproduction of a delicate sound in high frequency range has been achieved.
With a combination of the planar magnetic model's subtle high frequecies and the dynamic model's volume and open bass tones, you discover new things about music you're used to listening to when you use D8000; they have you wanting to listen to your favorite music over and over again. With this product, you realize that high sound quality provides the impetus for experiencing the deeper aspects of music.
In doing so, the shortcoming of planar magnetic models - the low reproducibility of bass tones - was solved. This technology could be considered a reinvention of planar magnetic models.
With D8000 Pro Edition, the problem with the diaphragm coming into contact with magnets has been solved through AFDS (Air Film Damping System), and it has become possible to reduce the frequency of the bass tones that the driver unit can reproduce. Combined with breatheable earpads, bass tone reproduction with a volume and open sound only achievable with superior dynamic models is possible.
We developed manufacturing apparatus such as a diaphragm formation machine and a diaphragm tension meter in-house, specifically for the D8000 series.
To create truly good products, it is necessary to get to the core of the manufacturing process of parts close to the raw material. What is good about "made in Japan" is that when doing so, you can gain the cooperation of those manufacturers close to the material. By contolling everything together, from sourcing the raw materials through to the assembly of the product, we have achieved high-quality products.
Cable length: 1.5m
Input: 3.5mm, 3-Pole
Output: 3.5mm, 2-Pole with locking function
Compatible models: D8000/D8000 Pro Edition, SONOROUS VIII/VI/IV/III/II
Cable length: 3m
Input: 6.3mm, 3-Pole
With D8000, the reproduction band of bass frequencies has been extended through AFDS, and it has become possible to sufficiently reproduce bass frequencies even with earpads that are not sealed tightly just with driver unit ability. The earpads that greatly influence sound quality have been newly developed specially for D8000 from highly-breatheable foam and specialized fibers. For the D8000 Pro Edition, close attention has been paid to good feeling texture and longevity. Toray Ultrasuede has been used for parts that come in contact with the human skin.
- Product code
- FI-D8PPAL(BLACK) / FI-D8PPALS(SILVER)
- Housing
- Aluminum magnesium alloy
- Driver
- AFDS Planer Magnetic
- Cable
- OFC black cable 1.5m, 3.5mmφ plug / OFC silver coated cable 3m, 6.3mmφ plug
- Sensitivity
- 98dB/mW
- Impedance
- 60Ω
- Weight
- 523g
- Cord length
- 1.5m/3m
