FiiO
FiiO R7 DAC and Headphone Amp
Regular price $549.99
Sale price $549.99 Regular price $699.99
1 of 10
FiiO
Compact All-in-One Hi-Fi Streaming Player and Amplifier
Wired, Wireless
The FiiO R7 All-in-One Desktop Hi-Fi Streaming Player & Amplifier is a cutting-edge audio solution that combines versatility, powerful amplification, and audiophile-grade performance in a sleek and compact design. Whether you're an audiophile, music enthusiast, or content creator, the FiiO R7 serves as the ultimate desktop companion. Acting as a streamer, amplifier, DAC, preamp, and music hub, the R7 seamlessly integrates into any modular Hi-Fi setup, delivering exceptional audio fidelity through its premium components and intuitive Android-based interface.
A Modular Hi-Fi Hub with Extensive Connectivity
The FiiO R7 features a comprehensive range of front and rear input/output ports, making it the centerpiece of a modular Hi-Fi system. Equipped with USB-C, RCA, optical, coaxial, and XLR inputs/outputs, the R7 can connect to headphones, active speakers, external DACs, and storage devices like microSD cards up to 2TB. For audio enthusiasts, the front outputs offer options like 6.35mm single-ended, 4.4mm balanced, and 4-pin XLR balanced headphone outputs, providing flexibility for different listening preferences. Whether you’re streaming music or improving external audio sources, the R7’s connectivity delivers unmatched versatility.
5-Inch HD Touchscreen with Android 10
The R7 features a stunning 5-inch HD portrait touchscreen with an intuitive GUI powered by Android 10. Enjoy access to popular streaming services like Spotify, Tidal, and Qobuz, or install third-party apps for expanded functionality. The touchscreen provides seamless navigation through menus, audio settings, and streaming options, while the open Android OS ensures future-proof customization. Control the R7 effortlessly through the touchscreen, the FiiO Music app, or the soon-to-be-available Bluetooth remote.
Audiophile-Grade Components for Exceptional Sound
The FiiO R7 is equipped with industry-leading components to ensure pristine audio quality. Featuring dual THX AAA 788+ headphone amplifiers and the powerful ES9068AS DAC, the R7 delivers crystal-clear sound with a wide dynamic range. Its 4th generation FPGA technology and dual femtosecond crystal oscillators minimize jitter and distortion, ensuring a pure and stable signal chain. Combined with five levels of gain adjustment, the R7 accommodates everything from sensitive IEMs to power-hungry headphones, producing 3.6W of power under a 32-ohm load.
Versatile Audio and Output Modes
The FiiO R7 offers multiple audio modes to suit a variety of listening preferences. Android Mode provides access to streaming apps, while Pure Music Mode optimizes the system for immersive, high-fidelity playback. Other modes include USB DAC Mode for improving external devices, Bluetooth Receiver Mode with support for LDAC, aptX, and AAC, and Roon Ready Mode for seamless integration with your Roon music library. Additionally, the output selection knob lets you switch between headphones, active speakers, or line-level outputs without unplugging devices, ensuring convenience and flexibility.
Clean Power with Advanced AC/DC Circuitry
The R7 integrates a robust 30W switching power supply with advanced AC/DC filtering technology to deliver clean and stable power. With features like tantalum capacitors for noise reduction, high-voltage LDO regulators, and a dedicated transformer shield, the R7 ensures minimal power interference for pristine audio output. Additionally, it supports external DC power supplies for further performance optimization, making it a reliable powerhouse for any Hi-Fi setup.
Built to Impress with Heat Management and Smart Features
Designed with precision, the R7 incorporates smart features like customizable RGB lighting, efficient honeycomb side vents for heat dissipation, and a personalized screensaver display with clock options. Its durable metal housing not only exudes elegance but also enhances heat management, allowing for continuous, stable operation. Whether used for music streaming, gaming, or professional audio work, the R7’s thoughtful design combines performance with aesthetics to elevate your desktop audio experience.
Feature Details
Display 5" HD LCD (720 x 1280)
DAC ES9068AS DAC
Amplifier Dual THX AAA 788+ Headphone Amps
Power Output 3.6W @ 32Ω
Audio Modes Android, Pure Music, USB DAC, Bluetooth, Roon
Bluetooth Codecs SBC, AAC, aptX, aptX HD, LDAC, LHDC
Inputs (Rear) 2 x RCA, 1 x Optical, 1 x Coaxial, 1 x USB-C
Outputs (Rear) 2 x XLR Balanced, 1 x Coaxial, 1 x Optical
Front Outputs 6.35mm, 4.4mm Balanced, 4-Pin XLR Balanced
Storage MicroSD (up to 2TB)
Connectivity Dual-Band Wi-Fi, Ethernet, USB-A, USB-C
Power Supply 30W Internal AC; Supports External DC (12V/3A)
Dimensions 6.3 x 5.3 x 4.3 inches (160 x 134 x 110 mm)
Weight 2.8 lbs (1282 g)
The FiiO R7 All-in-One Desktop Hi-Fi Streaming Player & Amplifier redefines desktop audio with its comprehensive functionality, audiophile-grade components, and seamless user experience. Whether you’re a seasoned audiophile or new to Hi-Fi, the R7 offers unparalleled sound quality, modular connectivity, and smart design features that make it the ultimate centerpiece for any audio setup.
What's In The Box
  • FiiO R7 All-in-One Desktop Hi-Fi Streaming Player & Amplifier (Black)
  • Power Cord
  • USB Data Cable
  • Flat Base
  • Angled Base
  • 2 x Dustproof Plug
  • 4 x Double-Sided Tape for Base
  • microSD Card Holder
  • Fuse
  • 6.35mm Adapter
