FiiO
FiiO M23 Portable Music Player
Redefining Portable Audio Performance
Portability
The FiiO M23 is a state-of-the-art portable Hi-Fi digital audio player (DAP) designed for audiophiles and music enthusiasts seeking uncompromised sound quality. With flagship-grade DACs, powerful amplification, and extensive connectivity options, the M23 offers the ultimate listening experience for both casual and critical listening. Its cutting-edge architecture and versatile operating modes make it the perfect companion for music lovers on the go.
Flagship Dual DAC Design for Exceptional Sound Clarity
The FiiO M23 is equipped with the flagship AKM AK4191EQ and AK4499EX DACs, a combination that ensures pristine sound reproduction. This advanced DAC design separates digital and analog components, utilizing "DWA Routing Technology" to significantly improve the signal-to-noise ratio. The result is a clean, high-resolution audio output with exceptional detail, perfect for immersive listening sessions across all genres.
8-Way Parallel Amplification for Immense Power
Building on the success of previous FiiO models, the M23 features dual 4-way balanced THX AAA-78+ amplifiers that deliver 8-way parallel amplification. This configuration produces an incredible power output while maintaining the precision and clarity necessary for audiophile-grade listening. The balanced output ensures robust and distortion-free playback, making it ideal for driving a wide variety of headphones.
Precision Audio Architecture and Power Supply
The M23 boasts a high-caliber audio architecture that incorporates DAC, I/V conversion, LPF, voltage amplification, and parallel amplification stages. Low-noise OPA1612 and OPA1662 op-amps ensure accurate playback and powerful amplification. A robust 4-stage, 20-rail power supply featuring 28 high-capacity tantalum capacitors delivers clean and stable power for optimal performance, ensuring every note is rendered with the utmost fidelity.
Advanced Features for Enhanced User Experience
The M23 is packed with features that elevate the listening experience. It includes dual-mode fast charging, allowing the device to charge at up to 30W for rapid power replenishment. The patented desktop mode enables continuous operation when connected to an external power source, eliminating battery concerns for extended listening sessions. Additionally, the Digital Audio Purification System (DAPS) minimizes jitter and ensures precise audio reproduction.
Versatile Operating Modes for Flexible Playback
With six distinct operating modes, the M23 adapts to your listening preferences and setup. Enjoy streaming services in Android Mode, experience immersive music in Pure Music Mode, or connect seamlessly with Roon Ready, Bluetooth, and AirPlay. It also supports DLNA playback, making it easy to access your music library from NAS devices or cloud storage. Whether you're streaming or listening to locally stored tracks, the M23 ensures a premium audio experience.
Stunning Design and Build Quality
The FiiO M23 is as aesthetically pleasing as it is functional. Its bold, stainless steel and aluminum chassis exudes premium quality and durability, while the 5500mAh battery ensures long-lasting performance. A vibrant display and intuitive interface provide effortless control, while its compact design makes it ideal for portable and desktop use alike.
| Feature | Details |
| Model | M23 |
| SoC | Snapdragon 660 |
| DAC | AK4191EQ + AK4499EX |
| Amplifier | Dual 4-way THX AAA-78+ |
| Audio Resolution | DSD256: 384 kHz / 32-Bit; DSD512: 768 kHz / 32-Bit |
| ROM | 64GB/46GB |
| Gain Modes | Super High, High, Medium, Low |
| Bluetooth | 5.0 SBC, AAC, aptX, aptX HD, LDAC, LHDC |
| Inputs/Outputs | 1/8" (3.5mm), 4.4mm balanced headphone, USB-C, Type-C |
| Battery | Rechargeable Lithium-ion Battery 5500mAh |
| Power Output | Up to 1000 mW at 32 Ohms (Balanced) |
| Dimensions | 3" x 5.4" x 0.7" |
| Weight | 10.5 oz |
What's in the Box
- FiiO M23 Digital Audio Player (DAP)
- Pre-installed screen protector
- Protective case
- USB-A to USB-C adapter
- Tray eject pin
- Type-C to Type-C charging cable
- GPL V2 manual
- Quick start guide
- Warranty card
Elevate Your Listening Experience with the FiiO M23
Available now at Headphones.com, the FiiO M23 combines premium performance, innovative design, and unparalleled versatility. Transform your portable audio experience with this exceptional device designed for audiophiles and casual listeners alike.
