FiiO
FiiO M17 Portable Music Player
Portability
Experience Portable Desktop-Class Audio with the FiiO M17 Portable Music Player
The FiiO M17 Portable Music Player delivers a desktop-class audio experience in a compact and portable form. With its cutting-edge design and premium components, this high-performance device is perfect for audiophiles who want exceptional sound quality on the go. From its dual ES9038PRO DACs to the THX AAA 788+ amplifier, the M17 offers precision-engineered hardware for clear, detailed, and immersive playback. Whether you're streaming, listening to high-resolution audio files, or using it as a desktop DAC/amp, the M17 provides unparalleled versatility and sound performance.
Dual ES9038PRO DACs for Exceptional Clarity
The M17 features dual 8-channel ES9038PRO DACs that deliver pristine audio reproduction. These flagship DACs process audio signals with ultra-high dynamic range and ultra-low distortion, ensuring every detail of your music is heard with exceptional clarity. Paired with the 4th-gen FPGA and NDK femtosecond clock system, the M17 achieves precise timing and minimizes jitter for a purer listening experience.
THX AAA 788+ Amplifier for Powerful Performance
The integrated THX AAA 788+ amplifier provides up to 3000mW of output power per channel at 32Ω, making it capable of driving demanding headphones with ease. The amp's fully balanced architecture ensures clean, distortion-free amplification for an authentic soundstage. The M17 also includes four gain levels, allowing you to optimize the output for different headphones and in-ear monitors.
Versatile Connectivity and Storage Options
The M17 is designed to be the centerpiece of your audio setup, offering a variety of inputs and outputs for versatile use. Connections include balanced and unbalanced headphone outputs, RCA coaxial in/out, and dual USB-C ports. The device also features 64GB of internal storage and a microSD card slot that supports up to 2TB, providing ample space for your high-resolution music library.
Intuitive Interface and Display
With a 5.99-inch HD touchscreen and physical controls, navigating the M17's features is effortless. The Android 10 operating system enables you to install third-party apps, access streaming services, and customize your experience. The 120-step volume adjustment can be controlled via the analog knob or buttons, providing precise control over your listening levels.
Advanced Cooling and Design
The M17 incorporates advanced cooling technologies, including "H"-type heat dissipation, VC liquid cooling, and a built-in fan, to maintain optimal performance during extended use. The aluminum alloy unibody frame not only ensures durability but also adds a premium feel to the device. Its 7-color RGB ambient lighting system provides customizable aesthetics that can match your style or mood.
Long Battery Life and Desktop Mode
Equipped with a massive 9200mAh battery, the M17 delivers up to 10 hours of continuous playback. For extended listening sessions, the desktop mode allows the M17 to draw power directly from an external adapter, preserving the battery's lifespan. This feature also unlocks a higher gain level for driving even the most power-hungry headphones.
| Specification | Details |
| DAC | Dual ES9038PRO |
| Amplifier | THX AAA 788+ |
| Audio Resolution | PCM: 384 kHz / 32-Bit, DSD256: 11.2896 MHz |
| Battery | 9200mAh, up to 10 hours playback |
| Storage | 64GB internal, microSD up to 2TB |
| Inputs/Outputs | RCA, USB-C, 2.5mm, 3.5mm, 4.4mm, 6.35mm |
| Display | 5.99" HD (2160 x 1080) |
| OS | Android 10 |
| Bluetooth Codecs | AAC, aptX, LDAC, LHDC |
| Dimensions | 3.5 x 6.2 x 1.1 inches |
| Weight | 610g |
What's in the Box
- FiiO M17 Desktop-Class Digital Audio Player
- External DC Adapter
- Cooling Stand with Built-in Fan
- Leather Case
- USB 3.0 Data and Power Cable
- USB Power Cable for DC Adapter
- Aluminum Dust Plug
- microSD Card Ejector Pin
- Quick Start Guide
- Limited 1-Year Manufacturer Warranty
The FiiO M17 is available now at Headphones.com, offering audiophiles a top-tier portable music player with desktop-class performance. Transform your listening experience with its unrivaled power, precision, and versatility.
