FiiO
FiiO M15S Portable Music Player
Portability
The FiiO M15S Portable Music Player delivers an audiophile-grade listening experience in a compact, portable package. Designed for discerning music enthusiasts, the M15S combines state-of-the-art components, versatile connectivity, and intuitive features, making it an ideal choice for music lovers who demand premium sound quality on the go. From the cutting-edge ES9038PRO DAC to the advanced QCC5124 Bluetooth chip, the M15S is engineered to meet the highest standards of performance and versatility.
Flagship-Grade DAC for Unparalleled Clarity
The FiiO M15S incorporates the flagship ES9038PRO DAC, featuring eight independent D/A converters split between two channels. This configuration ensures rich, highly detailed sound with exceptional clarity. Complementing this is FiiO's 4th-generation FPGA+NDK DAPS, which leverages phase-locked loop technology and dual femtosecond crystal oscillators to minimize jitter and produce a cleaner, purer audio signal. Whether you're enjoying high-resolution audio or streaming music, the M15S guarantees a premium listening experience.
Versatile Output Options for Any Audio Setup
With multiple output options, the M15S is versatile enough to power anything from sensitive in-ear monitors to high-impedance over-ear headphones. It offers 3.5mm single-ended, 2.5mm balanced, and 4.4mm balanced headphone outputs, ensuring compatibility with a wide range of headphones. The device also features a rotary volume control with 120 steps for precise adjustments, while RGB lights provide customizable visual feedback for volume and status.
Desktop-Grade Performance in Portable Mode
The M15S is equipped with a massive 6200mAh battery, offering up to 10.5 hours of playback on a single charge. For stationary listening, its desktop mode unlocks enhanced performance, providing access to a fifth gain level for over-ear headphones. In this mode, the device uses a higher-voltage power supply, preserving battery life while delivering up to 1200mW per channel—enough to drive the most demanding headphones with ease.
Advanced Bluetooth and Connectivity Options
Featuring the QCC5124 chip, the M15S supports two-way Bluetooth 5.0 with high-quality codecs like LDAC, aptX HD, and aptX Adaptive. This ensures seamless wireless streaming and excellent sound quality when paired with compatible devices. It also supports DLNA, AirPlay, and Roon Ready modes, making it easy to integrate into your home or portable Hi-Fi setup.
Exceptional Build Quality and Thermal Management
The M15S is constructed with premium materials, including a nickel copper shield for the audio circuit and a graphene heat dissipation system. These design elements ensure consistent performance by keeping the device cool, even during demanding playback sessions. The 5.5-inch HD touchscreen and intuitive Android 10 interface make navigation effortless, while its sleek and durable design ensures it’s as stylish as it is functional.
Comprehensive Audio Modes for Custom Listening
The M15S offers six operating modes to cater to your specific audio needs, from Pure Music mode for immersive listening to USB DAC mode for enhancing the sound quality of connected devices. Its second harmonic adjustment and 10-band PEQ provide fine-tuning capabilities, allowing users to tailor their listening experience to their preferences. Whether you're a casual listener or an audiophile, the M15S delivers exceptional sound customization options.
| Feature | Details |
| Model | M15S |
| DAC | ES9038PRO (8-channel, 32-bit) |
| Processor | Qualcomm Snapdragon 660 |
| Bluetooth | AAC, aptX, aptX Adaptive, aptX HD, aptX LL, LDAC, LHDC, SBC |
| Display | 5.5" LCD (1440 x 720 Resolution) |
| Battery | 6200mAh Rechargeable Lithium-ion Battery |
| Battery Life | Up to 10.5 hours |
| Charging Time | 3.5 hours |
| Outputs | 3.5mm, 2.5mm balanced, 4.4mm balanced |
| Storage | 64GB Internal, microSD Slot (Up to 2TB) |
| Audio Resolution | Up to DSD512, 768 kHz / 32-Bit |
| Weight | 12.2 oz / 345 g |
| Dimensions | 3.1 x 5.5 x 0.7 in / 80 x 140 x 18.9 mm |
| Gain Modes | Low, Medium, High, Enhanced Over-Ear Headphones |
What's In the Box
- FiiO M15S Portable Music Player
- Premium leather case
- DK3S heat dissipation dock
- PD charging/data cable
- USB power cable for DK3S
- USB adapter
- microSD card removal pin
- Quick start guide
- Warranty card
Elevate Your Music Experience with the FiiO M15S
Available now at Headphones.com, the FiiO M15S sets a new standard for portable Hi-Fi players. With its flagship components, versatile connectivity, and unparalleled performance, it’s the ultimate choice for audiophiles on the move.
