FiiO
FiiO FT1 Pro Headphones
Cup style
Wearing style
Driver type
Amp required
Portability
The FiiO FT1 Pro Open-Back Headphones represent the next step in FiiO’s FT series, delivering unparalleled sound quality with a combination of planar magnetic technology and open-back design. Tailored for audiophiles, these headphones merge cutting-edge engineering with elegant ergonomics, creating a listening experience that is both immersive and comfortable. Whether you're a casual listener or a seasoned enthusiast, the FT1 Pro promises a pristine and expansive soundstage.
Featuring FiiO's second-generation planar driver technology, the FT1 Pro is designed to outperform in its price category, making it an excellent choice for critical listening and home audio setups.
FiiO’s Revolutionary Planar Magnetic Driver
The FT1 Pro is powered by a proprietary 95x86mm planar magnetic driver, designed entirely in-house by FiiO. Unlike off-the-shelf planar drivers, this innovative system integrates a 1μm ultra-thin diaphragm with a patented dual-coating of sapphire and aluminum. The result? Exceptional clarity, responsiveness, and a frequency range extending up to 40kHz. This unique construction enables the FT1 Pro to reproduce rich bass, transparent mids, and detailed highs with precision and depth.
Despite its advanced driver system, the FT1 Pro maintains a lightweight build of just 374g, ensuring comfort even during long listening sessions.
Sapphire-Aluminum Dual Coating for Enhanced Fidelity
To achieve class-leading performance, FiiO has employed a patented dual-coating system on the planar diaphragm. The aluminum coating enhances conductivity, improving the dynamic response and reducing impedance, while the sapphire layer increases rigidity and treble accuracy. This thoughtful pairing of materials provides a balanced yet highly detailed sound signature, making every note and nuance in your music come alive.
Listeners will appreciate the FT1 Pro’s ability to deliver a wide dynamic range, making it suitable for a variety of music genres, from classical and jazz to electronic and rock.
Open-Back Design for an Expansive Soundstage
The FT1 Pro’s open-back design ensures a natural and spacious listening experience. By allowing sound waves to travel freely through the metal grid earcup covers, the headphones reduce unwanted resonance and reflections, creating an authentic and immersive soundstage. This makes the FT1 Pro an excellent choice for critical listening in quieter environments, as it delivers an airy and open presentation that closed-back headphones cannot replicate.
Perfect for at-home use, the FT1 Pro provides an expansive and detailed auditory experience that rivals headphones at higher price points.
Ergonomic Comfort Meets Durability
The adaptive 3-axis headband of the FT1 Pro adjusts seamlessly to different head sizes, ensuring a snug and secure fit. The lightweight steel rails enhance durability without adding unnecessary weight, while the lychee leather headband padding offers a soft and luxurious feel. The breathable fabric ear pads further enhance comfort, efficiently dissipating heat and providing a secure fit for long listening sessions.
With its sophisticated design and precision engineering, the FT1 Pro strikes the perfect balance between comfort, durability, and style.
Versatile Connectivity and Accessories
The FT1 Pro includes two high-quality detachable cables to suit your audio setup: a 3.5mm single-ended cable and a 4.4mm balanced cable, both constructed from silver-plated oxygen-free copper for optimal signal transmission. A 3.5mm to 6.3mm adapter is also provided, making the headphones compatible with a wide range of devices, from portable audio players to desktop DAC/amps.
A premium softshell storage case is included for convenient transport and protection, making the FT1 Pro an excellent choice for both home and on-the-go listening.
| Feature | Specification |
| Driver | Planar Magnetic |
| Impedance | 20Ω |
| Sensitivity | 112dB/Vrms (@1kHz) / 95dB/mW (@1kHz) |
| Frequency Response | 7Hz-40kHz |
| Weight | 374g (without cable) |
| Cable Material | Silver-plated oxygen-free copper |
| Cable Length | 150cm |
What’s Included:
- FiiO FT1 Pro Headphones
- 4.4mm Balanced Cable
- 3.5mm Single-Ended Cable
- 3.5mm to 6.3mm Adapter
- Storage Case
- Quick Start Guide
- 1-Year Warranty
With its sophisticated planar technology, premium materials, and ergonomic design, the FiiO FT1 Pro is perfect for audiophiles who demand uncompromised sound quality and comfort. Available now at Headphones.com, the FT1 Pro sets a new benchmark for performance and value in open-back planar magnetic headphones.
