FiiO
FiiO BTR7 Portable DAC and Headphone Amp
Regular price $159.99
Sale price $159.99 Regular price $199.99
1 of 11
FiiO
Wireless
Experience Portable Hi-Fi Audio with the FiiO BTR7 Portable Bluetooth DAC and Headphone Amplifier
The FiiO BTR7 brings a world of high-resolution audio to the palm of your hand. This compact and lightweight Bluetooth DAC and headphone amplifier combines cutting-edge components with a stylish design, making it perfect for music enthusiasts on the go. Featuring advanced DACs, THX AAA-28 amplifiers, dual headphone outputs, and a 1.3" IPS color display, the BTR7 offers unparalleled audio performance in a sleek and portable package.
Dual DACs and THX AAA Amplifiers for Pristine Audio Quality
Equipped with two ESS ES9219C DAC chips and dual THX AAA-28 amplifiers, the FiiO BTR7 delivers an exceptional audio experience. This combination ensures distortion-free sound with incredible detail and clarity, supporting PCM playback up to 32-bit/384kHz, DSD256, and MQA. Whether you're listening to your favorite tracks or exploring new genres, the BTR7's fully balanced audio architecture guarantees an immersive and accurate listening experience.
Seamless Connectivity with Bluetooth 5.1 and Dual Outputs
The FiiO BTR7 features Bluetooth 5.1 for seamless wireless connectivity, with support for high-resolution codecs like LDAC, aptX HD, and aptX Adaptive. Additionally, it includes both a 3.5mm single-ended output and a 4.4mm balanced output, giving you the flexibility to connect various headphones. With its dual output options and versatile Bluetooth compatibility, the BTR7 ensures a superior audio experience tailored to your setup.
Advanced Audio and Charging Technologies
The BTR7 incorporates FiiO’s innovative 3-level Hi-Fi audio architecture, including a high-performance DAC, low-pass filter, and THX amplifiers, capturing every nuance of your music. Its 880mAh battery supports both USB-C wired fast charging and convenient Qi wireless charging. This dual charging capability ensures you can keep your device powered up wherever you are, so your music never stops.
Patented Metal Antenna Design for Stable Connections
FiiO has integrated its patented seamless metal frame antenna design into the BTR7, ensuring stable and interference-free Bluetooth connections. This advanced design guarantees reliable performance, even in challenging environments, while maintaining the sleek, stylish appearance of the device.
Intuitive Control and App Customization
The BTR7 is easy to use, with a 1.3" IPS color display that provides clear information and controls. Additionally, the companion app enhances usability by offering customizable EQ settings and OTA firmware updates. Whether you prefer inline controls or app-based adjustments, the BTR7 adapts to your preferences for effortless operation.
Feature Details
DAC Chips Dual ESS ES9219C
Amplifier Chips Dual THX AAA-28
Bluetooth Version 5.1
Bluetooth Codecs LDAC, aptX HD, aptX Adaptive, aptX, AAC, SBC
Bluetooth Profiles A2DP, AVRCP, HFP, HSP
Audio Resolution PCM 32-bit/384kHz, DSD256, MQA
Headphone Outputs 3.5mm single-ended, 4.4mm balanced
Output Power (3.5mm) 165mW @ 16 Ohms, 160mW @ 32 Ohms, 18mW @ 300 Ohms
Output Power (4.4mm) 235mW @ 16 Ohms, 320mW @ 32 Ohms, 40mW @ 300 Ohms
Frequency Response 20Hz - 50kHz ±0.5dB
Signal-to-Noise Ratio 118dB (3.5mm), 115dB (4.4mm), A-weighted
THD+N < 0.00055% (3.5mm), < 0.00048% (4.4mm)
Maximum Output Voltage 2.3Vrms (3.5mm), 3.2Vrms (4.4mm)
Impedance 1.2 Ohms (3.5mm), 2.8 Ohms (4.4mm)
Display 1.3" IPS color
Battery Capacity 880mAh
Charging Options USB-C wired, Qi wireless
Battery Life Approx. 9 hours
Charging Time 1.5 hours
Dimensions 3.3 x 1.6 x 0.6 inches (83.6 x 39.6 x 14.6 mm)
Weight 2.4 oz (68 g)
Construction Laminated aluminum alloy with seamless metal antenna
USB Audio Support PCM up to 384kHz, DSD256
Companion App Features EQ customization, OTA firmware updates
What's In the Box
  • FiiO BTR7 Portable Bluetooth DAC and Headphone Amplifier
  • Leatherette Case
  • USB Type-C Charging Cable
  • Short USB Type-C Data Cable
  • Limited 1-Year Manufacturer Warranty
The FiiO BTR7 is your ultimate portable solution for audiophile-grade sound. Order now on Headphones.com and enjoy cutting-edge Bluetooth audio wherever you go.
