FiiO
FiiO BTR17 Bluetooth DAC And Headphone Amp
Amplifier type
Wireless
Portability
Introducing the FiiO BTR17, a versatile portable Bluetooth DAC and headphone amplifier that elevates your audio experience. Designed for audiophiles and casual listeners alike, the BTR17 combines cutting-edge technology with user-friendly features, making it an essential addition to your audio setup.
Advanced Bluetooth Connectivity for Seamless Audio Streaming
The BTR17 utilizes Qualcomm's flagship QCC5181 Bluetooth chip, supporting Bluetooth 5.4 and the latest LE Audio standard. This advanced chipset ensures high-resolution audio streaming with support for codecs like LDAC and aptX Lossless, delivering CD-quality sound wirelessly.
Dual DACs and THX Amplification for Superior Sound Quality
Equipped with dual ESS ES9069Q DAC chips and THX AAA 78+ amplifiers, the BTR17 offers exceptional audio performance. This configuration provides a balanced and detailed sound signature, ensuring your music is reproduced with clarity and precision.
Versatile Connectivity Options for Various Audio Setups
The BTR17 features both 3.5mm unbalanced and 4.4mm balanced outputs, accommodating a wide range of headphones and earphones. Additionally, it functions as a USB DAC via its USB-C port, allowing you to connect it to your computer for high-quality wired audio playback.
User-Friendly Design with Intuitive Controls
Designed with user convenience in mind, the BTR17 includes a physical volume knob and a 1.3-inch IPS color display that provides clear information on settings and statuses. Its compact and robust aluminum body, complemented by an elegant leather back panel, ensures durability and a premium feel.
Long Battery Life and Quick Charging for On-the-Go Use
With a built-in 1200mAh battery, the BTR17 offers extended playback time, making it ideal for daily commutes or long listening sessions. The USB-C fast charging feature ensures minimal downtime, keeping your music going when you need it.
| Specification | Details |
| DAC Chips | Dual ESS ES9069Q |
| Amplifier | THX AAA 78+ |
| Bluetooth Chipset | Qualcomm QCC5181 |
| Bluetooth Version | 5.4 |
| Supported Codecs | LDAC, aptX Lossless, aptX Adaptive, aptX HD, aptX, AAC, SBC |
| Outputs | 3.5mm unbalanced, 4.4mm balanced |
| Display | 1.3-inch IPS color display |
| Battery Capacity | 1200mAh |
| Dimensions | 16.3mm x 41.2mm x 86.6mm |
| Weight | Approximately 73.4g |
| USB DAC Processor | XMOS XU316 |
| Supported Sampling Rates | Up to 384kHz/32-bit PCM, DSD256 |
| MQA Support | Full decoding |
| Equalizer | 10-band PEQ |
| Desktop Mode | Supported |
| Volume Control | Physical knob |
| Color Options | Black, Blue |
What's in the Box
- FiiO BTR17 Bluetooth DAC and Headphone Amplifier
- USB-C charging cable
- User manual
- Warranty card
Experience unparalleled wireless audio with the FiiO BTR17, available now at Headphones.com. Elevate your listening experience with this feature-packed, high-performance device.
