Ferrum Audio
Ferrum WANDLA HP DAC and Headphone Amplifier
Regular price $3,695
Sale price $3,695 Regular price $3,695.00
1 of 5
Ferrum Audio
Versatile All-In-One Solution
The Ferrum Wandla HP Fully Balanced DAC/Preamp with Headphone Amplifier is a groundbreaking addition to Ferrum's acclaimed lineup. Designed as a single-box solution for audiophiles who demand exceptional performance for both headphones and speaker systems, the Wandla HP combines the functionality of a flagship-quality headphone amplifier, preamplifier, and DAC into one elegant unit. Offering fully balanced topology, a proprietary ARM-based platform, and Ferrum’s hallmark minimalistic design, the Wandla HP is an audio powerhouse that bridges the gap between affordability and high-end audio engineering.
Engineered for seamless integration with various audio setups, the Wandla HP offers six digital inputs and an analog input for diverse connectivity options. Whether you’re connecting headphones, speakers, or high-fidelity sources, the Wandla HP guarantees an unmatched audio experience.
High-Performance Headphone Amplification
The Wandla HP introduces an integrated balanced headphone amplifier capable of delivering up to 3.5 watts into 50 ohms, ensuring powerful performance even for the most demanding headphones. With a dynamic range of 122 dB, the amplifier reveals intricate details across the entire frequency spectrum, from the deepest lows to sparkling highs.
For single-ended users, Ferrum includes a high-quality 4.4mm to 6.35mm adapter, ensuring compatibility without compromising sound quality. Its smart, minimalist front-panel design keeps the 4.4mm Pentaconn headphone output as the only visible connection, delivering both simplicity and elegance.
Advanced Digital Filtering with Signalyst Collaboration
Ferrum has partnered with Signalyst, renowned for their HQPlayer software, to bring exclusive Dynamic Digital Filtering (DDF) options to the Wandla HP. These filters, designed specifically for the unit, provide users with precise control over their sound signature, making it possible to fine-tune playback to their exact preferences.
As Ferrum continues to engage with the audio community, additional filters will be made available, ensuring the Wandla HP evolves alongside user needs. This level of customization sets a new standard for DACs and preamps, offering a truly interactive listening experience.
Balanced Design for Pristine Sound
The Wandla HP employs a fully balanced composite IC headphone amplifier design, ensuring signal integrity and minimizing distortion. Its ESS Sabre ES9038PRO DAC chip, paired with Ferrum's advanced current-to-voltage conversion, delivers high-resolution audio with stunning clarity and precision.
Equipped with balanced XLR and unbalanced RCA outputs, the Wandla HP accommodates any high-fidelity audio setup. The analog input bypasses digital processing, maintaining the purity of high-quality analog sources for true audiophile-grade performance.
Ergonomic and Intuitive User Interface
The Wandla HP features a high-resolution touchscreen display with an intuitive user interface that combines touch, turn, and press functionalities for effortless operation. The sleek design ensures quick access to settings, making it a breeze to customize your audio experience.
Its modern aesthetic, highlighted by Ferrum's signature minimalist design, ensures that the Wandla HP is as visually appealing as it is functional. Whether on your desk or part of your home audio setup, the Wandla HP is a statement piece that complements any environment.
Enhanced Performance with HYPSOS Integration
While the Wandla HP includes a high-quality power supply, its performance can be further elevated when paired with Ferrum's HYPSOS power system (sold separately). Using Ferrum’s proprietary FPL cable, HYPSOS optimizes power delivery deeper into the Wandla HP circuitry, unlocking an even higher level of audio fidelity. This seamless pairing ensures that the Wandla HP can adapt and grow with your audio system over time.
The Ultimate Solution for Headphone and Speaker Enthusiasts
Whether you're a dedicated headphone listener or a speaker system enthusiast, the Ferrum Wandla HP offers unparalleled performance and versatility. Its flagship-level features, compact design, and advanced customization options make it the perfect choice for audiophiles seeking an all-in-one solution without compromise. Elevate your listening experience with the Wandla HP, now available on Headphones.com.
Headphone Amplifier
Specification Value
THD Balanced 0.00016% (-116 dB, 10mW into 50Ω)
Output Power Balanced 3.5 W into 50Ω
Output Power Single-Ended 1 W into 50Ω
Dynamic Range 122 dB
DAC and Inputs
Specification Value
DAC Chip ESS Sabre ES9038PRO
Resolution 768kHz/32-bit, DSD512
Digital Inputs USB-C, AES, Optical, Coax, ARC, I2S
Analog Inputs RCA
Build and Connectivity
Specification Value
Power Inputs DC Connector + Proprietary FPL
Outputs XLR (Balanced), RCA (Unbalanced)
Remote Control Included
Weight 1.90 kg (4.19 lbs)
Discover the Ferrum Wandla HP and redefine your audio expectations. Available now at Headphones.com!
