Ferrum Audio
Ferrum Power Splitter
Regular price $285
Sale price $285 Regular price $285.00
1 of 6
Ferrum Audio
Regular price $285
The Ferrum Power Splitter (FPS) is a groundbreaking solution designed for audiophiles who demand the best from their audio equipment. Developed in response to customer feedback, the FPS allows you to power two devices simultaneously with just one HYPSOS power supply. This innovative accessory ensures that your audio setup remains streamlined and efficient, without compromising on sound quality.
*If you are looking to use the Ferrum Hypsos, Ferrum Oor and Ferrum WANDLA at the same time, an additional Ferrum Power Link (FPL) cable is required. You will need three FPL cables total.
Key Features of the Ferrum Power Splitter
The Ferrum Power Splitter boasts several key features that make it an essential addition to any high-end audio system. It is engineered to maintain the correct output settings, including voltage and polarity, ensuring the optimal operation of all connected devices. The inclusion of a Ferrum Power Link (FPL) cable in the box adds to the convenience, providing a seamless connection between your HYPSOS and the FPS.
Customization Options for Your Unique Setup
Understanding that every audio setup is unique, Ferrum offers customization options for the Power Splitter. You can choose from different lengths of power cords, including the FPL, to suit your specific requirements. These options are available at an extra charge, allowing you to tailor your audio system to your exact preferences.
Power Consumption Considerations
When using the Ferrum Power Splitter, it's important to be mindful of the combined power consumption of the connected devices. The FPS is designed to handle a maximum power consumption of 80W and a current of up to 6A. Ensuring compatibility with the power supply configuration of your devices, such as center positive polarity and appropriate voltage, is crucial for optimal performance.
Compatibility with Ferrum MicroUSB
For those utilizing the Ferrum MicroUSB in conjunction with the Power Splitter, it's essential to adhere to the correct voltage settings of 5 volts and positive polarity. This attention to detail guarantees that your devices operate harmoniously, delivering an unparalleled audio experience.
Elevate Your Audio System with the Ferrum Power Splitter
The Ferrum Power Splitter is a must-have accessory for audiophiles seeking to enhance their audio systems. Its thoughtful design, customization options, and attention to power consumption make it a valuable addition to any setup. Experience the difference in your audio quality with the Ferrum Power Splitter, available now at Headphones.com.
