Eversolo
Eversolo DAC-Z8 Desktop DAC and Amp
Regular price $749
Sale price $749 Regular price $749.00
1 of 6
Eversolo
Regular price $749
The Pinnacle of Audio Precision
Delivering Reference Sound with Versatility
The Eversolo DAC-Z8 stands as a paragon in the world of desktop DACs and amps, designed to deliver reference sound quality whether using wired or wireless sources. Its incorporation of the ES9038Pro DAC with XMOS XU316 ensures sound processing perfection, setting a new standard for audiophile-grade listening experiences.
Advanced Digital Audio Processing
At the core of the DAC-Z8's prowess is the ESS Sabre flagship ES9038Pro 32-bit D/A converter chip, paired with the XMOS XU316. This combination guarantees maximum precision in audio processing, supporting formats up to DSD512 Native and PCM768KHz@32Bit decoding. The low jitter dual-clock oscillators further enhance the digital audio performance, ensuring synchronous processing and optimal audio precision.
Seamless Mobile Integration
Connecting your mobile phone to the DAC-Z8 is effortless with the EverSolo app, providing complete control over the device. This integration allows users to fully harness the capabilities of the DAC-Z8 and tailor their listening experience directly from their smartphones.
Fully Balanced Audio Circuit
The DAC-Z8 boasts a fully balanced audio circuit, ensuring that external noise is effectively eliminated. This design contributes to the device's ability to deliver pure and undisturbed sound, making it an excellent choice for audiophiles seeking unparalleled audio fidelity.
Flexible Input Options
The DAC-Z8 offers a plethora of input options, including Optical, Coaxial, USB, and Bluetooth 5.0 with aptX HD and LDAC support. These diverse input sources are complemented by a 3-inch LCD screen that displays input source, quality, and volume. Users can also opt for the mobile app for enhanced control and monitoring.
Powerful and Precise Output
The DAC-Z8 focuses on delivering powerful and precise output. The integration of eight OPA1612 op-amps with shunt compensation technology and a low ripple power supply ensures a purer power source and low distortion preamp signal. The device excels with headphones ranging from 16-300 ohms impedance, offering exceptional performance.
Feature-Rich and User-Friendly Interface
Dual ES9038Q2M DACs in the DAC-Z8 operate independently for each channel, effectively reducing interference and background noise while improving the signal-to-noise ratio and dynamic range. A 3" LCD screen with a multifunction wheel provides a user-friendly interface, allowing easy configuration and control of the DAC.
Harnessing the Power of Smart Control
The DAC-Z8 is complemented by Android and iPhone/iPad control apps, enabling users to effortlessly manage key functions of the device. This smart control capability adds a layer of convenience, making the DAC-Z8 not only a powerhouse of performance but also a delight to use.
The Eversolo DAC-Z8 represents a fusion of advanced technology and user-centric design, creating an audiophile-grade desktop DAC and amp that excels in both performance and usability. Whether for professional studio use or personal high-fidelity listening, the DAC-Z8 is poised to redefine expectations and enhance the audio experience for all users.
Eversolo DAC-Z8 Technical Specifications
Display Screen 3" LCD Screen
Chassis Aviation aluminum alloy
DAC ES 9038Pro
Audio Processor XMOS XU316O
PA Chip OPA1612 *10
Power Supply Low noise switching power supply
Bluetooth Audio Input Qualcomm QCC5125 Bluetooth module, BT5.0, SBC/AAC/aptX/aptX LL/aptX HD/LDAC
USB-B + USB-C DAC Input Compatible with Windows (7, 10), Mac, Android and IOS up to stereo DSD512, PCM 768KHz 32Bit and MQA
Optical / COAX Audio Input Up to stereo PCM 192KHz 24Bit, DSD64 Dop and MQA
Analog Audio Output Preamp output: XLR (BAL), RCA; Headphone amp output: 6.3mm SE
USB Port (x1) USB2.0 (only for firmware upgrade)
Control Methods Remote control, mobile APP control and knob control
Headphone Impedance 16-300Ω (low gain mode:16-32Ω/high gain mode: 32-300Ω
Power Input AC 110~240V 50/60Hz
Rated Power 9W
Dimensions 270mm(W) * 187mm(D)* 50mm(H)
XLR Output
Output level (Vrms) 4.1Vrms@0dBFS
THD+N@A-wt 0.000062%@1kHz (-124dB@1kHz)
THD+N@No-wt 0.000069%@1kHz (-123dB@1kHz)
Noise@No-wt <1.2uVrms
SNR @No-wt 133dB@1kHz
Frequency response 20Hz-20kHz (±0.1dB)
Crosstalk -130dB@1kHz
DNR @No-wt 133dB@1kHz
RCA Output
Output level (Vrms) 2.3Vrms@0dBFS
THD+N@A-wt 0.000086%@1kHz (-121dB@1kHz)
THD+N@No-wt 0.000097%@1kHz (-120dB@1kHz)
Noise @No-wt <1.5uVrms
SNR @No-wt 126dB@1kHz
Crosstalk -123dB@1kHz
DNR@No-wt 126dB@1kHz
Headphone (low gain)
Output level(Vrms) 1.2Vrms@0dBFS
Maximum undistorted power 45 mW@32Ω
THD+N@A-wt 0.00015%@1kHz(-116dB@1kHz)
THD+N@No-wt 0.00018%@1kHz(-115dB@1kHz)
Noise @No-wt <2uVrms
SNR@No-wt 124dB@1kHz
Frequency response 20Hz-20kHz(±0.1dB)
DNR @No-wt 119dB@1kHz
Headphone (high gain)
Output level(Vrms) 2.8Vrms@0dBFS
Maximum undistorted power 26 mW@300Ω
THD+N@A-wt 0.00016%@1kHz(-116dB@1kHz)
THD+N@No-wt 0.00016%@1kHz(-116dB@1kHz)
Noise@No-wt <2uVrms
DNR @No-wt 124dB@1kHz
