ELAC
ELAC Debut 3.0 DA43 2-Way Dolby Atmos Speaker - Pair
Amp required
Portability
The ELAC Debut 3.0 DA43 is a 2-way up-firing speaker module designed to add Dolby Atmos height effects to compatible surround sound systems. Use the DA43 on top of your existing left and right speakers or mount it to the wall via the integrated keyhole mount to create a more immersive overhead presentation. The sealed MDF cabinet in a black ash finish and a removable magnetic grille provide a clean, modern look that integrates easily into a home theater setup.
Key Features
- Up-firing 2-way speaker module designed for Dolby Atmos height effects
- 1 inch aluminum dome tweeter for clear high frequency detail and wide dispersion
- 4 inch woven aramid fiber cone mid-woofer for tight, controlled output with low distortion
- Sealed enclosure with internally braced MDF cabinet for reduced resonance
- Magnetically attached removable cloth grille for a clean, hardware-free front look
- Flexible placement as a speaker topper or on a tabletop or bookshelf
- Keyhole wall-mount option with optional hardware
- 5-way binding post input for standard speaker cable connections
Sound and Use Case
DA43 is intended for home theater listeners who want a more dimensional soundstage by adding height information for Atmos mixes. The up-firing design reflects sound off the ceiling to create an elevated layer for effects and ambience. The aluminum dome tweeter focuses on clarity and detail, while the aramid fiber mid-woofer supports accurate, controlled output. A sealed, internally braced cabinet helps minimize coloration so Atmos cues remain clean and precise.
| Model | ELAC Debut 3.0 DA43 |
| Speaker Configuration | 2-way, up-firing Dolby Atmos module |
| Enclosure Type | Sealed |
| Drivers | 1 x 1 inch aluminum dome tweeter (up-firing), 1 x 4 inch woven aramid-fiber cone mid-woofer (up-firing) |
| Crossover Frequency | 2200 Hz (high-pass) |
| Frequency Response | 48 Hz to 38 kHz (-6 dB), 60 Hz to 34 kHz (-3 dB) |
| Impedance | 6 ohms |
| Sensitivity | 88 dB |
| Power Handling | 60 W RMS per channel, 80 W peak per channel |
| Recommended Amplifier Power | 20 to 120 W per channel |
| Input | 5-way binding post pair input |
| Cabinet Material | MDF |
| Finish | Black ash |
| Grille | Removable cloth grille, magnetic attachment |
| Placement Options | Speaker topper, tabletop or bookshelf, wall-mount via keyhole mount (optional hardware) |
| Floor Contacts | Adjustable rubber feet |
| Dimensions (Each) | 6.8 x 6.7 x 9.7 inches (172 x 170 x 246 mm) |
| Weight (Each) | 7.3 lb (3.3 kg) |
| Package Weight | 17.315 lb |
| Box Dimensions (L x W x H) | 16.2 x 13.8 x 10.4 inches |
What’s in the Box
- ELAC Debut 3.0 DA43 2-way Dolby Atmos speaker modules (pair, black)
- Limited 3-year manufacturer warranty
