EarMen
EarMen Angel Portable DAC and Headphone Amplifier
Regular price $399
Sale price $399 Regular price $599.00
1 of 10
EarMen
Regular price $399
Elevate Your Audio with EarMen Angel
Introducing the EarMen Angel, a marvel of modern audio engineering, designed to satiate the most discerning audiophiles and professionals. This premium DAC and headphone amplifier combo is not just a device; it's your gateway to an extraordinary auditory journey, offering unparalleled sound quality and versatility.
High-Resolution Audio at Your Fingertips
The Earmen Angel stands out with its capability to play back high-resolution audio up to 32-bit/384kHz and DSD256. Immerse yourself in a world where every note is captured with astonishing clarity and precision. From the subtlest nuances in your favorite classical piece to the intricate layers of an electronic beat, the Earmen Angel reveals the true essence of sound.
Power Meets Versatility
Designed to accommodate a broad spectrum of headphones, the Earmen Angel effortlessly drives everything from the most sensitive IEMs to high-impedance studio-grade headphones. Its robust amplification ensures that every track is infused with richness and depth, bringing your music collection to life like never before.
Portability Redefined
The Earmen Angel isn't just powerful; it's also incredibly portable. Its sleek, compact design makes it an ideal travel companion, ensuring that top-tier audio quality is always within reach. With a convenient USB-C connection, integrating this audio powerhouse into your digital ecosystem is a breeze.
Reference Portable Device
Discover the EarMen Angel, your portable powerhouse for on-the-go high-resolution audio. Boasting a fully balanced architecture and equipped with a 2-cell battery, the Angel ensures you enjoy an abundance of power without compromising on playback time. It's not just an amplifier; it's your ticket to soaring through your favorite tracks wherever life takes you.
Supreme DAC Performance
At the heart of the EarMen Angel lies the ESS DAC ES9038Q2M, renowned for its exceptional SNR and THD + N parameters. Coupled with the cutting-edge XMOS USB receiver, it decodes audio up to 768kHz/32 bit PCM, DSD256 via DoP, and MQA Studio, ensuring every detail of your music is rendered with utmost precision.
Experience True Balance
The EarMen Angel is a testament to audio purity, maintaining a fully balanced signal from the DAC straight to your headphones. The absence of additional capacitors and components in the audio signal path means the sound you hear is as authentic as it gets, free from any coloration or distortion.
Dynamic Audio Like Never Before
With an astounding dynamic range of 120dB, the Angel brings your music to life, offering a realism that feels like you're right there at the live performance. Its linear power supply, characterized by ultra-low noise, contributes to an even more transparent and detailed sound, elevating your listening experience to new heights.
MQA Studio Quality and Powerful Battery Life
Embrace studio-quality audio with MQA support and uninterrupted listening sessions, thanks to the robust dual-cell 2x3000mAh battery. With a charge time of under 3 hours and the ability to run continuously when connected to a charger, the EarMen Angel ensures your music never stops.
Gain Control and Versatile Connectivity
Enhance your listening with Gain + mode, offering more power, volume, and dynamic sound. Angel's versatility extends to its headphone jack options, providing both 3.5mm single-ended and balanced 4.4mm outputs, and an intuitive Line Out feature for seamless integration as a Pre Amp in your home system. With the EarMen Angel, you hold the power to tailor your audio experience to perfection.
