Dunu
Dunu TopSound Studio SA6 In-Ear Headphones
Cup style
Wearing style
Driver type
Dynamic, Balanced Armature
The Newly Developed 6 Balanced Armatures Earphone
With times of testing with different drivers, our acoustic engineers finally go with the Knowles and Sonion balanced armatures for the Dunu TopSound Studio SA6 in-ear monitor headphones. Each frequency is located with 2BA and with the tuning, you will enjoy a powerful bass, smooth and natural mids, and flexible and transparent highs.
Two Different Tuning Switches
We know you may want to custom your earphone so we have embedded two tuning switches on the Dunu TopSound Studio SA6 In-Ear Monitor Headphones for your preference. The standard modes is more balanced in three frequencies while the Atmospheric Immersion mode has more powerful bass and more immersive. Custom switch is more stable and easier to operate
Exquisite Solid Wood Faceplate
Dipped and dyed with color ink, each solid wood faceplate presents a fully unique textures and color from one another. Along with hand-poured UV Acrylic resin, each product displays diverse beauty like the infinity universe
Detachable 8 Core OCC Silver-plated Cable
Each pair of SA6 comes with a 8 core high-purity Furukawa OCC silver-plated cable. The inside wires adopts coaxial configuration double layer conductor and HDPF insulating layer. The sound is purer and more stable with it
Included Patented Interchangeable Plugs
For SA6, we have included rich accessories to better meet your needs. It includes one 3.5mm single-end plug, one 2.5mm balanced plug, 4.4mm balanced plug. The patented DUNU technology makes it true to meet most devices in the market. No more converter or worrying about compatibility, simple got this and you have it all!
- Frequency Response: 5 Hz - 40 kHz (HI-RES certified)
- Impedance: 60 Ω at 1 kHz
- Sensitivity: 113 ± 1 dB at 1 kHz
- Total Harmonic Distortion: < 0.5% at 1 kHz
Driver Configuration
- Bass (2): Sonion AcuPass Vented Dual Woofer
- Midrange (2): Knowles Custom Midrange Driver (×2)
- Treble (2): Knowles Custom Dual Tweeter
Tuning Modes
- Default Signature (Switch Position ‘I’)
- Atmospheric Immersion (Switch Position ‘ON’)
Housing Materials
- Shell: German Nice-Fit Hand-Poured UV Acrylic Resin
- Faceplate: High-Grade Stabilized Wood
Cable Specifications
- Wire Material: 8 Core, High-Purity, Monocrystalline, Silver-Plated Copper
- Length: 1.2 ± 0.1 m
- Connector: 2-Pin (0.78 mm)
- Plug Connector: Patented DUNU Quick-Switch Modular Plug System
- Included Plug Termination(s):
4.4 mm TRRS Balanced, 3.5 mm TRS Single-Ended, 2.5 mm TRRS Balanced
