Denon
Denon HEOS Amplifier HS2 2 Ch. 100W Amp - Clearance
Regular price $329
Sale price $329 Regular price $499.00
Save 34%
1 of 4
Denon
On saleClearance
Regular price $329
Save 34%
Denon HEOS Wireless Amplifier
The Denon HEOS Amp brings modern wireless streaming and multi-room functionality to any pair of passive loudspeakers. Designed to integrate seamlessly into the HEOS ecosystem, it delivers the same ease of use as Denon’s self-powered HEOS speakers while giving you the freedom to choose your own speakers.
Turn Any Speakers into a Wireless Zone
With the HEOS Amp, your favorite stereo speakers become part of a whole-home audio system. Stream music wirelessly, group rooms together, or play different music in each space using the HEOS app. It is a simple way to modernize an existing speaker setup without replacing hardware you already love.
Clean Power for Real-World Listening
The built-in stereo amplifier delivers 70 watts per channel into 8 ohms, with ample current to handle a wide range of speakers. Whether you are listening casually or turning things up, the HEOS Amp maintains control and clarity across the full frequency range.
Built on Denon’s Audio Heritage
Backed by more than a century of audio engineering, the HEOS Amp is hand-tuned to deliver natural, balanced sound. Denon’s focus on detail and musicality ensures your speakers perform at their best, whether streaming, playing local files, or listening to internet radio.
HEOS Streaming and Connectivity
Powered by the HEOS platform, the amplifier supports a wide range of streaming services, local network playback, USB storage, and Bluetooth. It also supports Dolby Digital and Dolby Digital+ for compatibility with TV and home entertainment setups.
Product Highlights
  • Stereo wireless streaming amplifier
  • 70W per channel into 8 ohms
  • Single-zone amplifier with HEOS multi-room support
  • Supports Dolby Digital and Dolby Digital+
  • USB input for local playback
  • Wide streaming service and file format support
  • Ethernet and dual-band Wi-Fi connectivity
Amplifier Type Stereo
Rated Output Power 70W + 70W (8Ω, 20Hz to 20kHz, THD 0.05%)
Frequency Response 20Hz to 20kHz ±1.5dB
Speaker Impedance 4 to 16Ω
Input Sensitivity 150mV
Input Impedance 47kΩ
Total Harmonic Distortion 0.1% (1kHz)
Signal to Noise Ratio 83dB (IHF-A)
Networking Ethernet, dual-band Wi-Fi 802.11 a/b/g/n/ac
Bluetooth Yes
USB Support Yes
Dimensions 3.7 x 8.74 x 8.43 inches
Weight 6.2 lbs
Finish Gunmetal silver with black sides
Supported Audio Formats
  • MP3, AAC up to 320kbps
  • WMA up to 192kbps
  • WAV, ALAC, FLAC up to 24-bit/192kHz
  • DSD 2.8MHz and 5.6MHz
Streaming and Music Services
  • Spotify, TIDAL, Amazon Music, Pandora
  • SiriusXM, TuneIn, SoundCloud, Deezer
  • Internet radio via TuneIn
  • Local music from NAS or USB storage
What’s in the Box
  • Denon HEOS Amp
  • Power cord
  • 3.5mm setup cable
  • Ethernet cable
  • Quick Start Guide
FAQ
Can I use the HEOS Amp with my existing speakers?
Yes. The HEOS Amp is designed to power passive speakers with impedances from 4 to 16 ohms, making it compatible with most home loudspeakers.
Does the HEOS Amp support multi-room audio?
Yes. Using the HEOS app, you can group the amplifier with other HEOS devices or play different music in different rooms.
Can I connect a TV to the HEOS Amp?
Yes. The amplifier supports Dolby Digital and Dolby Digital+ and can be used as part of a TV or home entertainment setup.
