Denon
Denon DP-3000NE
Regular price $2,799
Sale price $2,799 Regular price $2,799.00
1 of 12
Denon
Denon DP-3000NE
Denon DP-3000NE
Premium direct drive Hi-Fi turntable
Unmatched Precision with Direct-Drive Technology
Experience flawless playback with the Denon DP-3000NE Direct-Drive Turntable. Engineered with a high-performance direct-drive motor, this turntable achieves full speed almost instantaneously and maintains exceptional stability at all three playback speeds (33 1/3, 45, and 78 rpm). Unlike belt-driven systems, the direct-drive design ensures longevity without the need for future belt replacements.
Elegant S-Shaped Tonearm for Optimal Tracking
The DP-3000NE features a beautifully crafted 9.6-inch S-shaped tonearm designed to provide the ideal tracking angle throughout record playback. This tonearm includes height adjustment (0-9mm), allowing precise alignment with various moving-coil (MC) or moving-magnet (MM) cartridges. With adjustable anti-skating and cartridge weight settings, customize your turntable for optimal sound performance.
Advanced Motor Control for Smooth Operation
Utilizing Space Vector PWM (SV-PWM) motor control, the DP-3000NE provides ultra-stable rotation, significantly reducing harmonics that could otherwise lead to torque fluctuations and overheating. This advanced algorithm delivers constant voltage and frequency output, maintaining consistent, high-quality playback for extended listening sessions.
Robust Power Supply Design
Equipped with a switch-mode power supply (SMPS), the DP-3000NE significantly minimizes vibrations, enhancing overall sound clarity and reliability. This integrated power solution eliminates external power bricks, protecting against power grid variations, thus ensuring clean and steady voltage for superior audio performance.
Solid Construction and Luxurious Design
Crafted with precision, the DP-3000NE features a high-density MDF plinth finished in a luxurious dark ebony wood veneer. This robust construction effectively dampens resonance, providing a stable platform for superior audio fidelity. The turntable’s aesthetic elegance perfectly complements any high-end audio setup.
Enhanced Isolation with Adjustable Feet
Four adjustable insulator feet provide exceptional acoustic isolation, significantly reducing vibrations from external surfaces. Easily fine-tune the height to ensure the platter remains perfectly level, resulting in accurate needle tracking and pristine audio playback free of unwanted resonance.
Flexible Cartridge Compatibility
The Denon original headshell supplied with the DP-3000NE supports an extensive range of MC and MM phono cartridges. Included counterweights accommodate cartridge weights ranging from 4.0 to 26.0 grams, offering unparalleled versatility to match your specific audio preferences.
Effortless Integration and Connectivity
Easily connect the DP-3000NE to your amplifier or receiver via its stereo RCA analog outputs and dedicated ground terminal. For amplifiers without a built-in phono stage, simply add an external phono preamp to enjoy audiophile-grade vinyl playback.
Tehcnical Specifications
Specification Details
Drive System Direct
Motor 16-pole, 12-coil, brushless motor
Control Method PWM Vector
Platter Aluminum diecast (305mm)
Platter Inertia 382 kg/cm²
Wow and Flutter Less than 0.06% JIS
Speed Tolerance Less than ± 0.3%
Rumble (S/N Ratio) Over 70dB
Bearing Type Miniature Steel Ball Bearing
Tone Arm Static Balanced S-Shaped
Arm Length 244 mm
Overhang 14 mm
Offset Angle 20.5°
Tracking Error Angle 2.5° (Max.)
Suitable Cartridge Weight 4 to 16g (without sub weight), 14 to 26g (with sub weight)
Stylus Force Adjustment 0 - 2.5g / rotation
Height Adjustment Range 9mm
Anti-Skating Adjustment 0-3g
Headshell Material Aluminum
Sensitivity (Horizontal) 30mg
Sensitivity (Vertical) 30mg
Operation Manual
Speed 33 1/3 / 45 / 78 rpm
Control Start / Stop
Colors Dark Ebony
Dimensions (W x D x H) 500 x 394 x 185mm
Weight 18.5 kg
Power Supply AC 100-240V, 50/60Hz
Power Consumption <4W
Standby Power Consumption Less than 0.3W
Carton Maximum Dimensions (W x D x H) 615 x 515 x 335 mm
Carton Weight 24.0 kg
What's In the Box
  • Denon DP-3000NE Turntable
  • Tonearm (pre-installed)
  • Denon original Headshell
  • 6.5-foot AC power cord
  • Die-cast Aluminum Platter
  • Platter Mat
  • Dust Cover
  • 38-inch RCA Stereo Cable
  • 59-inch Ground Wire
  • 45RPM Adapter
  • Counterweight and Sub-counterweight
  • Denon EP Adapter/Weight
  • Overhang Gauge
  • Screws (Two each: 10mm, 13mm, 18mm)
  • Spacers (2)
  • Washers (2)
  • Screwdriver
  • Quick Start Guide
  • Safety Instructions
