Dekoni Audio
Dekoni Audio Elite Fenestrated Sheepskin Replacement Earpads for Sennheiser HD600 Headphones (Pair)
Regular price $69.99
Sale price $69.99 Regular price $69.99
1 of 4
Dekoni Audio
Modify or customize your Sennheiser HD600’s
The Sennheiser HD600 series of headphones are the standard in open back headphones.
Dekoni’s pads are a little deeper than the stock pads opening up the sound stage, and the slow rebound memory foam helps alleviate clamp force from any user, even when wearing glasses.
The soft, supple sheepskin wrapped it in dense, slow rebounding memory foam, increases isolation, comfort and sound stage.
The sheepskin and foam wrap create a tight but comfortable seal on your head, even if you wear glasses, to ensure that our discerning listeners have a great headphone experience.
The fenestrated sheepskin in the Elite Sheepskin Replacement for HD600 offers a more neutral bass reponse when compared to solid sheepskin.
Dimensions
Dekoni EPZ-HD600-FNSK, pad dimensions | Headphones.com
Compatibility
The EPZ-HD600 pads are fitted for the following Sennheiser models: HD58X Jubilee, HD600, HD650, HD660, HD660S, HD6XX.
Fenestrated Sheepskin vs. Stock Response
Dekoni EPZ-HD600-FNSK, graph of sheepskin vs stock earpads | Headphones.com
Replacement Instructions
