Dekoni Audio
Dekoni Audio Headphone Savior Charcoal V2 Carrying Case
Dekoni’s Headphone Savior has undergone a facelift! For those wanting to get the absolute maximum out of their softshell cases, the Version 2 is the perfect fit for you. Sporting an increased height for more room for attached cables or larger headphones, you’ll never need to worry about a tight squeeze again.
The Version 2 of the Headphone Savior introduces a raft of changes for those that weren’t able to find the original design to be a perfect fit. The defining feature of the Version 2 is the increased height, making clearance for the largest headphones we have on hand, including the Fidelio X2, LCD-2C and more.
Dekoni Audio’s Headphone Savior is built with the travelling audiophile in mind. Designed specifically to accommodate headphones, cables, DACs and anything else needed on the go, you’ll find quality protection that leaves you worry free.
With thick padding on all sides and a variety of possible configurations inside, you can trust the Savior to keep your investment safe; based on traditional camera bags, there’s no reason not to use the same philosophy that protects thousands in camera equipment for audio equipment as well!
The Version 2 of the Headphone Savior introduces a raft of changes for those that weren’t able to find the original design to be a perfect fit. The defining feature of the Version 2 is the increased height, expanding the original’s by 3cm.
Still not enough height? The Version 2 comes with the same two internal dividers, with one lining the bottom of the case; removing this frees up even more depth, maximizing the available space for any attached cables.
Included in the Savior are a variety of pockets and dividers, giving you the customization options needed to protect any style of headphone. At the bottom of the case is a smaller divider that can be removed to give some of the largest headphones available a little more breathing room, or make space for those with permanently attached cables.
The included shoulder strap makes for easy hands free travel, along with the climbing loop on the back for carabiners to quickly strap it to other bags.
