Dekoni Audio
Dekoni Audio Audio-Technica ATH-M50X Elite Sheepskin Ear Pads - Clearance
The pair of Audio-Technica ATH-M50X Elite Sheepskin Replacement Earpads from Dekoni are designed to replace your current earpads and bring your headphones to a like-new listening state. They are part of the Elite Series that is made from slow-rebound memory foam wrapped in fine, sheepskin leather. This ensures a tight, well-isolated fit, brings you closer to what it is you're listening to, and allows you to listen longer.
Key Features
- Premium Sheepskin Earpads
- Good Sound-Isolation Qualities
- Fits Audio-Technica ATH-M50x Headphones
- Fits ATH-M20x, M30x, and M40x Headphones
- Compatible with Sony MDR-7506
In the late 2000’s, Audio Technica changed the game releasing the original ATH-M50. The M50’s served not only the professional studio world, but also crossed over to the consumer mass market taking it by storm.
One of the best budget headphones, the sound is excellent, but the pads leave some room for improvement.
When you take soft, supple sheepskin and wrap it in dense, slow rebounding memory foam, you increase isolation, comfort and sound stage.
The sheepskin and foam wrap create a tight but comfortable seal on your head, even if you wear glasses, to ensure that our discerning listeners have a great headphone experience.
