Dan Clark Audio
Dan Clark Audio AEON CORE Headphones - Open Box
Cup style
Wearing style
Driver type
Amp required
Portability
All open box Dan Clark Audio AEON CORE are tested, inspected and cleaned by our meticulous returns time and are guaranteed to be in like-new condition.
The Dan Clark Audio AEON CORE is the next chapter in one of DCA’s most important headphone lines. As the direct successor to the AEON 2, AEON CORE keeps the same core promise that made the series such a long-running favorite: reference-minded planar magnetic performance, a closed-back design you can actually live with, and comfort that makes long listening sessions feel effortless.
At $899.99, AEON CORE is built to be the new entry point into Dan Clark Audio’s modern reference lineup. It introduces a new planar magnetic driver engineered for efficiency, consistency, and repeatable performance, along with a revised tuning target developed in collaboration with Dr. Sean Olive. The result is a closed-back planar headphone designed to sound natural, controlled, and easy to trust from a wider range of sources than previous AEON models.
A New Driver for Better Consistency
AEON CORE uses an all-new planar magnetic driver stack built around three priorities: efficiency, tonal consistency, and unit-to-unit reliability. This is Dan Clark Audio’s most easily driven headphone to date, with 97 dB/mW sensitivity and compatibility with amplifiers delivering at least 125mW into 16 ohms.
That matters because planar magnetic headphones are often associated with demanding amplification. AEON CORE is designed to be much easier to pair. It works comfortably with portable DAC/amps, quality dongles, and desktop gear, while still scaling with better amplification when you want to push the system further.
An Updated Reference Tuning
AEON CORE is the first Dan Clark Audio headphone tuned to a revised Harman over-ear target developed by Dan Clark in collaboration with Dr. Sean Olive. The goal was to better translate the original Harman research to today’s modern measurement systems, addressing the offset that appears when older target work is applied to current GRAS measurement fixtures.
In practice, AEON CORE is tuned to sound balanced, natural, and less forced than a typical “reference” headphone. Compared with prior AEON models, the voicing brings a slightly leaner upper bass, a gently lifted lower midrange, and a softer upper midrange. Vocals sit forward without turning hard. Acoustic instruments retain body and weight. Bass stays present and taut without overstating itself.
Closed-Back Planar Performance
Closed-back planar headphones are difficult to get right. They need isolation and control, but they also need enough openness and tonal balance to avoid sounding boxed in. ÆON CORE is designed to deliver the speed, low distortion, and clarity people expect from a planar magnetic driver, while keeping the practical advantages of a closed-back headphone.
That makes it a strong fit for desktop listening, office setups, travel rigs, and shared spaces where open-back headphones are not always practical. You get a more controlled listening environment without giving up the accuracy and resolution that define DCA’s planar designs.
Comfort That Defines the AEON Line
The AEON line has always been about more than sound. AEON CORE retains the physical design language that helped make the series so easy to recommend: DCA’s signature AEON earpads, a lightweight titanium headband, and a self-adjusting suspension strap that spreads weight naturally across the head.
The fit is secure, low-fatigue, and immediate. Whether you are listening for an album or settling in for a full workday, ÆON CORE is built around the kind of comfort that disappears once the music starts.
AEON CORE vs AEON 2
AEON CORE is the direct successor to AEON 2, but it is not just a cosmetic refresh. The biggest changes are in the driver, efficiency, consistency, and tuning target. The new driver makes AEON CORE easier to drive than previous AEON models, while the revised reference curve gives it a more current, research-informed tonal balance.
For listeners familiar with AEON 2, the shift should feel purposeful rather than dramatic for its own sake. AEON CORE keeps the closed-back planar appeal and everyday comfort of the series, while updating the acoustic foundation for better source compatibility, more consistent production, and a more refined reference tuning.
Key Features
- Closed-back planar magnetic headphone from Dan Clark Audio
- Direct successor to the AEON 2
- New planar magnetic driver stack engineered for efficiency and consistency
- DCA’s most easily driven headphone to date
- 97 dB/mW sensitivity
- Works with amplifiers delivering at least 125mW into 16 ohms
- Tuned to a revised Harman over-ear target developed with Dr. Sean Olive
- Slightly leaner upper bass, lifted lower mids, and softer upper mids compared with prior ÆON models
- Natural vocal presentation without upper-mid hardness
- Taut, controlled bass with reference-minded balance
- Signature AEON earpads for long-session comfort
- Titanium headband with self-adjusting suspension strap
- Designed and assembled in the United States
- Launch price: $899.99
Technical Specs
| Product Type | Closed-back planar magnetic headphone |
| Price | $899.99 |
| Driver Type | Planar magnetic |
| Driver Notes | New driver stack engineered for efficiency, tonal consistency, and unit-to-unit reliability |
| Sensitivity | 97 dB/mW |
| Recommended Amplifier Power | At least 125mW into 16 ohms |
| Tuning Target | Revised Harman over-ear target developed by Dan Clark Audio with Dr. Sean Olive |
| Design | Closed-back over-ear |
| Headband | Titanium headband with self-adjusting suspension strap |
| Earpads | Dan Clark Audio ÆON earpads |
| Manufacturing | Designed and assembled in the United States |
