Capra Audio
Capra Comfort Strap for Sennheiser HD 600 Series Headphones
Upgrade Your Listening Experience
Enhance the comfort of your headphones with the Capra Audio Comfort Strap. Scientifically designed for optimal support, this professional-grade strap provides a secure and comfortable fit. Say goodbye to discomfort and hello to long-lasting listening enjoyment.
Use Your Headphones For Hours
Go the distance! With a Capra Strap on your headphones you'll be able to use your headphones for longer periods of time without hurting your head! Game, Code, Edit, or just enjoy the music for longer than ever before!
Protect Your Investments
Capra Straps suspend your head away from the headband meaning the material of your headband wont wear out as fast, keeping your re-sale value UP and your maintenance costs DOWN! The Capra Strap wont flake or crack like leather, its easy to clean, easy to install and easy to enjoy!
Compatible Sennheiser Headphones:
HD600
HD650
HD660s
HD660s2
HD58x
HD6xx
HD580
