Cambridge Audio
Cambridge Audio EVO 75
Portability
All-in-One Simplicity: Just Add Speakers
The Cambridge Audio EVO 75 All-In-One Player and Integrated Amp offers a seamless blend of streaming capabilities and high-class amplification in a single unit. With the EVO 75, all you need to do is choose your speakers and streaming service to enjoy thrilling sound quality. Say goodbye to a mess of cables and hello to straightforward functionality, all packed into a sleek and stylish box that never goes out of fashion.
Easy Setup and User-Friendly Experience
Setting up the EVO 75 is a breeze. Simply connect it to the mains and your speakers, then use the StreamMagic app to connect to your network and select your favorite music streaming service. With just a few taps, you can start enjoying your music with the perfect volume and immerse yourself in the simplicity and ease of the EVO 75.
StreamMagic App: Full Control at Your Fingertips
The StreamMagic app provides complete control over the EVO 75, offering access to the most popular and high-resolution music streaming services. The app is designed to be clear, logical, and stable, ensuring that the EVO 75 does precisely what you want it to do. Whether you prefer to use the StreamMagic app or the app of your favorite streaming service, the EVO 75 is ready to deliver an exceptional listening experience.
Versatile Connectivity Options
With a range of digital and analog inputs, the EVO 75 can easily integrate into your existing system. It even supports video sources, allowing you to connect your TV's HDMI output to the EVO's ARC input. No matter the source of your music, the EVO 75 makes it easy to stay in control and enjoy your favorite tunes.
Bluetooth Convenience with Hi-Res Sound Quality
The EVO 75 takes Bluetooth streaming to the next level with Bluetooth aptX HD, offering wireless, high-definition music streaming from compatible devices. It's also equipped with Bluetooth aptX HD transmission, making it perfect for private listening on compatible Hi-Res wireless headphones.
Crafted for Audio Excellence
The EVO 75 is built with high-quality audio components, such as the ESS Sabre ES9016K2M Ultra DAC, and benefits from Cambridge Audio's 55+ years of audio expertise. The result is a performance that celebrates the talent of musicians and producers, retaining the original raw emotive power and detail of your music.
Complete Control and Intuitive Operation
Operating the EVO 75 is intuitive and straightforward, whether you're using the supplied remote control, the StreamMagic app, or the physical controls on the unit, including the large dual-concentric dial. It's designed for ease of use without compromising on functionality.
Designed for Alva Turntables and CD Compatibility
The EVO 75 is ready to pair with an Alva turntable, either through its integrated phono stage or via Bluetooth aptX for flexible placement. Additionally, the separately available Evo CD transport is the perfect companion for the EVO 75, allowing you to breathe new life into your CD collection and join the hi-fi evolution.
Timeless Design and Long-Term Enjoyment
With its award-winning design, premium materials, and confident sound, the EVO 75 is not just an audio player but a long-term musical partner. Its timeless looks and all-around good looks ensure that it deserves to be center stage in your audio setup, bringing pleasure to both your ears and eyes for many years to come.
| Specification | Detail |
| Power Output | 75W into 8 Ohms |
| Amplification | Class-D Hypex Ncore® |
| DAC | ESS Sabre ES9016K2M |
| Frequency Response | 20Hz – 20kHz +0/-3dB |
| Analog Audio Inputs | 1 x RCA |
| Digital Audio Inputs | 1 x TOSLINK optical, 1 x S/PDIF coaxial, 1 x TV ARC, Bluetooth (integrated) |
| Bluetooth | 4.2 A2DP/AVRCP supporting SBC, aptX and aptX HD codecs |
| Compatibility | TOSLINK optical: 16/24bit 32-96kHz PCM only S/PDIF coaxial: 16/24bit 32-192kHz PCM only Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD (24bit 48kHz) UPnP, Local USB media, Airplay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL, MQA, Qobuz, Roon Ready, ARC: 16/24bit 32-192kHz PCM only, Deezer |
| Audio Formats | ALAC, WAV, FLAC, AIFF, DSD (x256), WMA, MP3, AAC, HE AAC AAC+, OGG Vorbis |
| Outputs | Speakers, 3.5mm headphone, Preamp Output, Subwoofer Output, Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD |
| Ethernet | IEEE 802.3, 10 Base-T or 100 Base-T |
| Wi-Fi | Dual Band 2.4/5gHz |
| Max Power Consumption | 400W |
| Standby Power Consumption | <0.5W |
| Dimensions (W x H x D) | 317 x 89 x 352mm |
| Weight | 5.0 kg |
| What's in the Box | Evo 75 All-in-One Player, Quick Start Guide, Safety Guide, Remote Control, Mains Lead, 2 x AAA Batteries, Customisable Side Panels x 2 |
