Tomorrow's Hi-Fi, Today
The Cambridge Audio EVO 150 is a testament to the future of high-fidelity audio. With its powerful Hypex NCore Class D amplification and the class-leading StreamMagic streaming platform, the EVO 150 brings your audio past and present into the future. All you need to add are speakers to enjoy superb high-resolution audio quality from a single, elegant, and discreet box. Its suite of digital and analogue inputs, coupled with a high-quality digital-to-analogue converter, ensures that the EVO 150 can be the heart of your hi-fi system for years to come.
Easy to Set Up, Easy to Upgrade
Setting up the EVO 150 is a breeze. Simply connect it to the mains and your speakers, then use the StreamMagic app to connect to your network and start streaming your favorite music. The EVO 150 is designed for simplicity, but also offers the flexibility to upgrade and add functionality as your audio needs evolve.
StreamMagic App: Unparalleled Control
The StreamMagic app provides full control of the EVO 150, offering access to the world's most popular and high-resolution music streaming services. The app is intuitive, logical, and stable, ensuring that the EVO 150 will do precisely what you want, whether you're using the StreamMagic app or the app of your favorite streaming service.
Versatile Connectivity for All Your Needs
With a suite of digital and analogue inputs, including a built-in phono stage, the EVO 150 is ready to be the centerpiece of your audio system. Connect a turntable, EVO CD, or even your TV's HDMI output to the EVO's ARC input. No matter where your music comes from, the EVO 150 is equipped to handle it all.
Bluetooth Convenience with Hi-Res Sound Quality
The EVO 150 takes Bluetooth streaming to new heights with aptX HD Bluetooth, allowing for wireless, high-definition music streaming from compatible devices. Whether you're using our Alva turntables or enjoying private listening on compatible Hi-Res wireless headphones, the EVO 150 delivers convenience without compromising on sound quality.
Crafted by Music Enthusiasts
The EVO 150 is built with the finest audio components, including the ESS SABRE ES9018k2m Reference DAC, and is backed by Cambridge Audio's 55+ years of audio expertise. The result is a performance that celebrates the talent of musicians and producers, retaining the original raw emotive power and detail of your music.
Complete Control at Your Fingertips
Operating the EVO 150 is intuitive and straightforward, whether you're using the supplied remote control, the StreamMagic app, or the physical controls on the unit, including the large dual-concentric dial. It's designed for ease of use without sacrificing functionality.
Perfect Placement and Elegant Design
At 317mm wide, the EVO 150 is compact enough to fit neatly in your space, but its award-winning design and good looks mean it deserves to be the centerpiece of your audio setup. Its timeless appearance ensures that it will bring pleasure to both your ears and eyes for many years to come.
Embracing Vinyl with the EVO 150
For vinyl enthusiasts, the EVO 150's built-in phono stage is perfect for connecting turntables with moving magnet cartridges. The EVO 150's Bluetooth compatibility with our Alva turntables further enhances your vinyl listening experience.
A New Era for Your CD Collection
The Evo CD, available separately, is a compact disc transport developed exclusively to partner with Evo all-in-one players. Sharing the same eye-catching design and crafted from premium materials, the Evo CD extracts every detail from your discs and seamlessly integrates them into your EVO 150. This partnership ensures that your CD collection is ready to join the hi-fi evolution, revitalizing your music with the clarity and depth it deserves.
Designed to Thrill, Built to Last
The Cambridge Audio EVO 150 is more than just an all-in-one player and integrated amp; it's a long-term musical partner. Its confident sound, timeless looks, and premium materials mean that it will continue to bring pleasure to both your ears and eyes for many years to come. Whether you're a seasoned audiophile or a music enthusiast looking to elevate your listening experience, the EVO 150 is designed to thrill and built to last.
If you're ready to experience the future of hi-fi audio, visit Headphones.com to explore the Cambridge Audio EVO 150 and discover how it can transform your audio setup.
| Specification |
Detail |
| Power Output |
150W into 8 Ohms |
| Amplification |
Class-D Hypex Ncore® |
| DAC |
ESS Sabre ES9018K2M |
| Frequency Response |
20Hz – 20kHz +0/-3dB |
| Analog Audio Inputs |
1 x RCA, 1 x balanced XLR, 1 x Moving Magnet Phonostage |
| Digital Audio Inputs |
2 x TOSLINK optical, 1 x S/PDIF coaxial, 1 x TV ARC, Bluetooth (integrated), USB Audio |
| USB Audio Input |
USB Type B conforming to USB Audio Class 1 or USB Audio Class 2 (user selectable) |
| Bluetooth |
4.2 A2DP/AVRCP supporting SBC, aptX and aptX HD codecs |
| Compatibility |
TOSLINK optical: 16/24bit 32-96kHz PCM only S/PDIF coaxial: 16/24bit 32-192kHz PCM only USB Audio Class 1: Up to 24-bit 96kHz (asynchronous) USB Audio Class 2: Up to 24-bit 384kHz (asynchronous) and up to DSD 256 Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD (24bit 48kHz) UPnP, Local USB media, Airplay 2, Chromecast built-in, Internet Radio, Spotify Connect, TIDAL, MQA, Qobuz, Roon Ready, ARC: 16/24bit 32-192kHz PCM only, Deezer |
| Audio Formats |
ALAC, WAV, FLAC, AIFF, DSD (x256), WMA, MP3, AAC, HE AAC AAC+, OGG Vorbis |
| Outputs |
Speakers A+B, 3.5mm headphone, Preamp Output, Subwoofer Output, Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD |
| Ethernet |
IEEE 802.3, 10 Base-T or 100 Base-T |
| Wi-Fi |
Dual Band 2.4/5gHz |
| Max Power Consumption |
700W |
| Standby Power Consumption |
<0.5W |
| Dimensions (W x H x D) |
317 x 89 x 352mm |
| Weight |
5.3 kg |
| What's in the Box |
Evo 150 All-in-One Player, Quick Start Guide, Safety Guide, Mains Lead, Remote Control, 2 x AAA Batteries, Customizable Side Panels x 2 |
