Cambridge Audio
Cambridge Audio CXA81
                        Amplifier type
                        Portability
Cambridge Audio CXA81 Integrated Amplifier
Experience unparalleled sound quality with the Cambridge Audio CXA81 Integrated Amplifier, the four-time winner of What Hi-Fi? Product of the Year. With 80 watts per channel, this amplifier has the power to drive even the most demanding speakers, delivering balanced and efficient performance through its Class AB amplification. The toroidal transformer ensures incredible sound-staging, while the high-quality ESS Sabre ES9016 DAC brings out the best in your digital music.
Rewarding Performance
The CXA81 builds on the legacy of the first CX Series, combining over 50 years of amplifier expertise. This integrated amplifier offers a progressive perspective with effortless, poised, and sophisticated sound. Its 80 watts per channel provide complete authority over your music, revealing every emotion and nuance from both streamed and disc-based collections. The CXA81 promises a truly rewarding performance for discerning listeners.
Your World’s a Stage
From the first listen, the CXA81 reveals the intricate details in your music. Instruments, subtle shifts in tone, and harmonies are delivered with exceptional clarity. Close your eyes, and you can place every musician in the soundstage. This amplifier’s detailed sound reproduction ensures that once you experience it, there’s no turning back. The CXA81 transforms your listening space into a live performance stage.
Return on Investment
Cambridge Audio's engineering team in London dedicated countless hours to researching, developing, experimenting, and listening to ensure the CXA81 achieves the highest standards. Every component was selected and every decision made with the goal of delivering the most complete musical picture possible. The CXA81 is the culmination of this meticulous process, providing an exceptional return on investment for any music lover.
Effortlessly Musical
At the core of the CXA81 is a Class AB power amplifier stage with optimized capacitor values, blending the musicality of Class A with the efficiency of Class B. The amplifier’s short signal path minimizes interference, resulting in pristine sound that captures the emotional impact intended by the artist. The CXA81 delivers music that is both powerful and delicate, effortlessly musical in every sense.
Power with Control
Thanks to its generous toroidal transformer, the CXA81 delivers 80 watts of power per channel, with dual taps into the left and right of the amplification board, effectively giving each channel its own power supply. This design results in a vivid sound stage and handles dynamic shifts in music—those loud and quiet moments—with ease. The CXA81 provides power with precision and control.
Get the Message
The CXA81’s state-of-the-art digital circuit board features the cutting-edge ESS Sabre ES9016 digital-to-analogue converter (DAC). This ensures digital audio files, up to 32-bit/384kHz or DSD256, are reproduced with every subtle detail intact. The CXA81 combines unparalleled accuracy with vivid musicality, delivering an engaging and lifelike listening experience.
Get Connected
The CXA81 offers extensive connectivity options, including digital optical, coaxial, and USB audio inputs, stereo RCA inputs, balanced XLR sockets, and wireless hi-res connectivity via Bluetooth aptX HD. You can even connect a second set of speakers for multi-room audio. This amplifier is designed to meet all your connectivity needs, making it a versatile addition to any hi-fi system.
Designed for Life
Crafted from aluminium and steel, the CXA81 boasts elegant, minimalistic lines that will endure both physically and aesthetically. Thanks to the relentless dedication of our London team, the CXA81 is a complete solution that combines versatility, power, and audio excellence. It is designed to form the center of your musical experience for many years to come.
| Specification | Details |
| Power Output | 80W RMS into 8 Ohms, 120W RMS into 4 Ohms |
| DAC | ESS Sabre ES9016K2M |
| Frequency Response | <5Hz– 60kHz +/-1dB |
| Analogue Audio Inputs | 1x balanced XLR, 4 x RCA |
| Digital Audio Inputs | 1 x S/PDIF coaxial, 2 x TOSLINK optical, 1 x USB audio, Bluetooth (integrated) |
| Compatibility | TOSLINK optical: 16/24bit 32-96kHz PCM only, S/PDIF coaxial: 16/24bit 32-192kHz PCM only, USB: audio profile 1.0/2.0 (default 2.0), up to 24-bit 384kHz PCM, up to DSD256 or DoP256, Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD (24bit 48kHz) |
| Bluetooth aptX HD Receiver Built-in | Yes |
| Roon Tested | Yes |
| Outputs | Speakers A+B, 3.5mm headphone, Preamp Output, Subwoofer Output |
| Remote Control | Yes |
| Max Power Consumption | 750W |
| Standby Power Consumption | <0.5W |
| Dimensions (H x W x D) | 115 x 430 x 341mm (4.5 x 16.9 x 13.4”) |
| Weight | 8.7kg (19.1lbs) |
Box Contents
- CXA81 Integrated Amplifier
 - Power Cable
 - 3 x AAA Batteries
 - Remote Control
 - Control Bus Cable
 - Bluetooth Antenna
 - Quick Start Guide
 - Safety Guide
