Cambridge Audio
Cambridge Audio ALVA Solo
Moving Magnet Phono Preamplifier
                        Portability
Cambridge Audio ALVA Solo Phono Preamplifier
Discover the exceptional sound quality of your vinyl collection with the Cambridge Audio ALVA Solo Phono Preamplifier. This high-quality moving magnet phono stage is designed to bring out every last detail from your records, providing an immersive and rich listening experience. Whether you’re a vinyl enthusiast or just beginning your analog journey, the ALVA Solo ensures your records sound exactly as they should.
Vinyl as it's Supposed to Sound
The ALVA Solo Phono Preamplifier is crafted to preserve the unique warmth and depth of vinyl. It features a state-of-the-art switch mode power supply and a new surface-mounted circuit board layout, significantly reducing unwanted noise and interference. This meticulous design ensures that from the moment you drop the needle, you experience your music in its purest form.
Why Choose a Dedicated Phono Stage?
Turntables generate low-level signals that many hi-fi amplifiers cannot handle directly. A phono preamplifier like the ALVA Solo boosts this signal to a level suitable for power amplifiers, all while maintaining the integrity of the sound. Designed around exceptional components, the Solo delivers the warm, detailed sound that vinyl enthusiasts crave, without distorting the signal from your moving magnet cartridge.
Attention to Detail
The ALVA Solo is equipped with a subsonic filter to eliminate low-frequency rumbles caused by vinyl imperfections. Additionally, it features a balance control to handle potential cartridge imbalances in your record player, ensuring an accurate and detailed soundstage. These features ensure that even the most worn records can be enjoyed with clarity and precision.
Eco Friendly
The ALVA Solo Phono Preamplifier is designed with the environment in mind. It has a standby power consumption of less than half a watt and includes an auto power down feature that activates after 20 minutes of inactivity. This eco-friendly design also includes worldwide voltage compatibility, making it a versatile choice for vinyl lovers everywhere.
| Specification | Details |
| Max Power Consumption | 10W |
| Gain @ 1kHz | 39dB |
| Nominal Output | 300mV |
| Sensitivity for Nominal Output | 3.35mV |
| Equivalent Input Noise (A-Weighted) | ~0.09uV |
| RIAA Curve Accuracy | +/- 0.65dB 30Hz-20kHz |
| Signal to Noise Ratio (Grounded Inputs Ref. 1V Output, 20Hz-20kHz BW) | >90dB |
| THD+N 1kHz (20-20kHz BW) | <0.0025% |
| Input Impedance | 47k Ohm |
| Input Capacitance | 100pF |
| Overload Margin | >30dB |
| Crosstalk @10kHz | >85dB |
| Dimensions (H x W x D) | 48 x 176 x 132mm (1.9 x 6.9 x 5.2”) |
| Weight | 0.68kg (1.5lbs) |
What's in the Box
- ALVA Solo Moving Magnet Phono Preamplifier
 - User Manual
 - Safety Guide
 - Mains Lead
