Cabasse
Cabasse The Pearl Myuki Active Speaker
Wireless
Portability
Cabasse THE PEARL MYUKI is an ultra-compact, high-resolution connected active speaker designed to deliver a balanced, powerful sound from a minimal enclosure volume. Despite its small footprint, it is capable of up to 99 dB RMS output in mono, and up to 109 dB peak in stereo when paired with a second speaker. A DOM 45 midrange-tweeter and dual 12 cm bass drivers in a Push Push layout are engineered for firm, tight bass with impactful presence.
Designed for both home and travel, THE PEARL MYUKI supports a wide range of sources including TV, turntables, CD players, and network storage, and it can integrate into a whole-home Cabasse ecosystem using the StreamCONTROL app and AirPlay 2.
Key Features
- Compact high-resolution connected active speaker with powerful output for its size
- Mono playback up to 99 dB RMS, stereo pairing up to 109 dB peak stereo with a second speaker
- DOM 45 midrange-tweeter with dual 12 cm woofers in a honeycomb Push Push configuration
- High-performance battery for up to 12 hours of playback
- Smart Wi-Fi network optimization for uninterrupted listening
- Automatic room calibration with integrated microphone (CRCS)
- DFE mode for real-time power optimization based on volume, spectral content, and dynamics
- StreamCONTROL app support for streaming services, setup, and multiroom zone management
- Compatible with Cabasse connected systems, including THE PEARL COLLECTION and CLASSIC CONNECTED, with AirPlay 2 support
Sound and Use Case
THE PEARL MYUKI is built to sound full and controlled even at lower listening levels. The dual woofer Push Push architecture is designed to deliver precise, tight bass with deep resonance while operating within a very small enclosure volume. For larger rooms or more expansive listening, pairing two speakers for stereo increases scale and impact while preserving clarity and balance.
With multi-source support and automatic room calibration, THE PEARL MYUKI is well suited for living rooms, offices, bedrooms, and portable setups where you want high-resolution playback without a complex system. It can also be grouped with other compatible Cabasse connected speakers for multiroom listening.
Design and Controls
THE PEARL MYUKI features a lifestyle-focused design with rounded shapes and premium finishes in matte black or matte white with chrome accents. The woofers feature an embossed Lissajous pattern, and an integrated rear handle makes it easy to move from place to place. Control is handled via six illuminated tactile keys on the top of the speaker with subtle haptic vibration for clear feedback.
| Speaker Type | High-resolution connected active speaker |
| Output Level | 99 dB RMS mono, 109 dB peak stereo (with two speakers) |
| Frequency Range | 30 Hz to 23 kHz |
| Midrange Tweeter | DOM 45 |
| Woofers | 2 x 12 cm (4.72 inches) bass drivers in Push Push layout |
| Amplification | 65 watts treble, 76 watts woofer |
| Connectivity | Ethernet, Wi-Fi, Bluetooth, 3.5 mm jack, USB-C, SPDIF optical |
| Supported Audio Formats | MP3, WAV, AAC, WMA, AIFF, FLAC, ALAC, Ogg Vorbis, DSD 64 and 128, WMA Lossless |
| Room Calibration | Automatic room calibration (CRCS) with integrated microphone |
| Multiroom | High-resolution multiroom supported via StreamCONTROL app, compatible with AirPlay 2 |
| Controls | 6 illuminated tactile keys with haptic vibration (source, play pause, volume, power) |
| Battery Life | Up to 12 hours |
| Finish Options | Matte black or matte white with chrome accents |
| Dimensions | 7.3 x 6.9 x 7.1 inches |
| Weight | 2.1 kg |
What’s in the Box
- Cabasse THE PEARL MYUKI speaker
- Carrying bag
