Cabasse
Cabasse THE PEARL AKOYA Wireless Speaker - Pack of 2
Regular price $4,999
Sale price $4,999 Regular price $4,999.00
1 of 15
Cabasse
Wireless
Cabasse THE PEARL AKOYA is a compact co-axial wireless speaker designed to deliver high-resolution performance and powerful output from a refined, space-friendly form. Developed and manufactured in Brittany, France, THE PEARL AKOYA combines a tri-coaxial driver array with a dedicated bass loudspeaker for Cabasse Pure Sound, with output capable of reaching 115 dB in mono and 121 dB in stereo when paired with a second unit.
Recommended for rooms between 20 and 35 m2, THE PEARL AKOYA is built for versatile listening with multiroom and multisource capabilities, and it can be placed on a stand, on a surface, or mounted on the wall with an optional wall bracket.
Key Features
  • Compact high-resolution wireless speaker designed for rooms between 20 and 35 m2
  • Tri-coaxial driver design with 13 cm coaxial BCI midrange-tweeter and 17 cm HELD woofer
  • High output capability up to 115 dB in mono or 121 dB in stereo with a second speaker
  • StreamCONTROL integration for high-resolution multiroom playback across compatible Cabasse Wi-Fi speakers
  • Wireless streaming via Wi-Fi and Bluetooth
  • Wired connectivity including SPDIF optical, RCA analog, Ethernet, and USB for music on external hard drives
  • Programmable Bluetooth remote control with rotary volume ring and playback controls
  • Transportable design with a custom carry case included
  • Mounting flexibility with optional wall bracket or custom floorstand options
Sound and Use Case
THE PEARL AKOYA is designed for listeners who want a compact system that delivers scale, dynamics, and clarity in a single connected speaker. The coaxial driver architecture is intended to improve coherence by aligning key frequency ranges from the same point, while the HELD woofer supports deep, controlled bass output. In stereo mode with two speakers, output capability increases for larger spaces or higher listening levels.
With StreamCONTROL support, you can play the same music across multiple rooms or choose different sources by room when using compatible Cabasse connected speakers. For travel, a custom carry case is included to protect the speaker and reduce packing space.
Recommended Room Size 20 to 35 m2
Maximum Sound Level 115 dB mono, 121 dB stereo
Bandwidth 30 Hz to 27 kHz
Midrange Tweeter Driver 13 cm (5 inch) coaxial BCI
Woofer 17 cm (7 inch) HELD
Amplification, Tweeter 300 W RMS / 600 W peak
Amplification, Midrange 300 W RMS / 600 W peak
Amplification, Bass 450 W RMS / 900 W peak
Amplification Performance THD+N 0.005% (1W, 4 ohm), saturation 0, background noise 0 dB at 50 m (-15.5 dB SPL at 3 m)
Connectivity Ethernet, Wi-Fi, Bluetooth, SPDIF optical, RCA analog, USB for music on external hard drives
Audio Formats MP3, AAC, WMA, AIFF, FLAC, ALAC
DAC 32 bit / 768 kHz
Multiroom High-resolution multiroom (StreamCONTROL)
Remote Control Programmable Bluetooth controller
Dimensions (W x H x D) 22 x 22 x 22 cm (8.7 x 8.7 x 8.7 inches)
Weight 6 kg (18 lbs)
What’s in the Box
  • Cabasse THE PEARL AKOYA wireless speaker
  • Custom carry case
